F600 heater core
notjustair
PostPosted: Fri Oct 12, 2018 8:25 am    Post subject: F600 heater core Reply to specific post Reply with quote
I need a new heater core for the Ford F600. It?s a 1964. I assume it?s the same one used in the pickup, but I can?t even find one for a 64 pickup. Checked LMC, Dennis Carpenter, did a generic internet search, etc. They will go to 1965, but not 1864. Does anyone have an idea for getting a new one? I hate dealing with eBay but I might have to resort to it.
IanC
PostPosted: Fri Oct 12, 2018 8:57 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
Did the cab STYLE change from '65 to '65? If the cab didn't change the core probably didn't either. If your local Ford dealer was in business then see if they can get you a part number from an old book and search by number rather that description.
rustyfarmall
PostPosted: Fri Oct 12, 2018 9:10 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
I'm pretty sure that the F series style of cab was the same all the way from the F100 up through the F800. I can't imagine there would be much difference between the '61 through the '66 other than maybe the location of the heater hose connections.
Roger in Iowa
PostPosted: Fri Oct 12, 2018 9:51 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
Don't think it was even on the radar in 1864! Couldn't help it.
leroy in ne
PostPosted: Fri Oct 12, 2018 10:03 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
I checked Rockauto, no listing for 64,, checked 65, is there if you want to look at a picture of one. less than $30.00
shaun wallace
PostPosted: Fri Oct 12, 2018 10:05 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
There used to be a difference in core according to parts between recurlating and fresh air. Cab stayed same as 64-66 in 600 and larger. Check ford truck enthuist site for discussion on heater core in archives.
leroy in ne
PostPosted: Fri Oct 12, 2018 10:14 am    Post subject: Re: F600 heater core Reply to specific post Reply with quote
second thoughts, on pickups I beleive this was a major change year on some things, 64- straight front axle/ 65 twin I-Beam, engine sizes available?
russ1
PostPosted: Fri Oct 12, 2018 12:01 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
NAPA has it.
Heater Core
PART # :
NHC 6603555
shaun wallace
PostPosted: Fri Oct 12, 2018 4:22 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
Dennis Carpenter has it. P/N C5TZ-18476 B
VicS
PostPosted: Fri Oct 12, 2018 4:51 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
Cab didn't change till 67.
notjustair
PostPosted: Sat Oct 13, 2018 7:21 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
That?s for a 65 - doesn?t fit the same. This what I keep running into.
notjustair
PostPosted: Sat Oct 13, 2018 7:22 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
Again, for 1965 and later. 64 is not the same core.
notjustair
PostPosted: Sat Oct 13, 2018 7:24 pm    Post subject: Re: F600 heater core Reply to specific post Reply with quote
The cab isn?t markedly different, but the holes through the firewall for the lines are much different.
