Ford 871D
Dieseltech
PostPosted: Tue Oct 16, 2018 3:51 pm    Post subject: Ford 871D Reply to specific post Reply with quote
Is there any other way to determine the year when there's no traces of the serial number? Appears battery acid over time did a good job erasing the stamping. All I can tell so far is it's diesel, SOS transmission, with the late hood mounted air cleaner, single speed PTO. Could there be a chance the transmission was replaced, and never stamped? Thanks in advance.
Larry NCKS
PostPosted: Tue Oct 16, 2018 4:10 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
what number is on the transmission by your left heel? Is it C3NN- 7006 - B or is 312259?
Look at date code stampings on components. This has been just been discussed recently and my times before that. Do a search.
Look particularly at the tag on the radiator.
Dealers were to restamp original Model and S/N on replacement transmissions. Some didn't get done. However diesels were bad at etching the numbers away because of battery acid drip.
Dieseltech
PostPosted: Tue Oct 16, 2018 4:32 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Transmission has the 312259 on it.
Larry NCKS
PostPosted: Tue Oct 16, 2018 5:15 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
312259 is what it came from the factory with. That does not necessarily mean it's original, though.
Jack L
PostPosted: Tue Oct 16, 2018 6:42 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
My 671 SOS transmission has a 312259 number on it and the tractor is a 1959 based on it's serial number.
showcrop
PostPosted: Wed Oct 17, 2018 4:19 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
My '59 971 has no number and no evidence of acid damage. The radiator tag is 1959. It also has a Ford T&I tag.
Larry NCKS
PostPosted: Wed Oct 17, 2018 4:25 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
CVPost-Jack L wrote:
(quoted from post at 21:42:15 10/16/18) My 671 SOS transmission has a 312259 number on it and the tractor is a 1959 based on it's serial number.
312259 was the original SOS and OEM transmission in all '01 series tractors to the best of my knowledge. I think the C0NN-7006-B came out in 1960 in some of the of the earliest 000 series industrial modes, but not in ag models until the early 000s in late '62. Sometime in '63 (I'm not sure when) the C3NN-7006-B came out. Therefore this C3NN was the transmission that replaced the 312259 under the Ford SOS program in the mid '60s.
I have both a '63 (built in late '62) and a '64 4000 . The '63 has an OEM C0NN and the '64 has an OEM C3NN.
The 312259 transmission itself only pins the year of an ag tractor from '59 - late '62.
texfordfan
PostPosted: Wed Oct 17, 2018 8:26 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Larry NCKS wrote:
(quoted from post at 05:25:39 10/17/18)
I was able to use the engine casting number to help me in this regard. It showed an engine that was cast in 1958 & '59. Since my tractor was a SOS which wasn't available in '58, it was most likely that my tractor was a '59 model. My 'blue' transmission wasn't stamped like it was supposed to have been and I've found the same problem on several gas 901s.
Sean in PA
PostPosted: Thu Oct 18, 2018 4:59 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Was one date on the block and the other on the head, or were both numbers on the block?
texfordfan
PostPosted: Thu Oct 18, 2018 8:16 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 05:59:15 10/18/18)
I took the number off the block
Sean in PA
PostPosted: Fri Oct 19, 2018 2:35 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
texfordfan wrote:
(quoted from post at 00:16:50 10/19/18)
The reason that I asked is that any piece that is cast is is only cast once, so how could it have been cast twice in 2 different years? Is one perhaps a casting date and the other an assembly date?
texfordfan
PostPosted: Fri Oct 19, 2018 9:46 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 03:35:20 10/19/18)
I could be wrong here, but I believe they used that casting two different years from what several people have told me on this site
Sean in PA
PostPosted: Fri Oct 19, 2018 11:26 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
texfordfan wrote:
(quoted from post at 13:46:22 10/19/18)
OK, I think I understand what you were trying to say. Yes, the casting design number (C0NN6015S, or whatever) could be used for multiple years, but the specific engine block in your tractor was only cast once, and it should also have a date code that is cast into that specific block in your tractor that will tell you the exact date that it was cast. I thought that was what you were referring to when you said it was cast in the two different years, that there were two different casting date codes.
texfordfan
PostPosted: Fri Oct 19, 2018 6:24 pm    Post subject: Re: Ford 871D Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 12:26:15 10/19/18)
Sorry I confused you, you're right, my block was cast in '59.
Sean in PA
PostPosted: Sat Oct 20, 2018 5:22 am    Post subject: Re: Ford 871D Reply to specific post Reply with quote
No problem at all. My brain has always been one that tries to interpret things literally and that has caused misunderstanding/confusion quite a number of times. I troubleshoot computer problems as my job, and I am always having to ask clarifying questions just to make sure that my understanding of the problem is what the customer understands that they are describing to me. It's even worse now that I work from home and do all of my troubleshooting via question and answer and depend on the customers descriptions of the symptoms. Back when I would go on site to the customers offices I could see things for myself and it was much easier to figure out what was going on.
