1975 ford 3400 cab heat help
66ford3000
PostPosted: Sat Oct 27, 2018 1:52 pm    Post subject: 1975 ford 3400 cab heat help Reply to specific post Reply with quote
I installed a cab on my ford 3400 diesel and I need help with the plumbing for the heater core, I see a plug on the lower rad hose aluminum inlet but I don't see anything on the thermostat housing or water pump and not sure where to plumb it correctly, thanks
Bern
PostPosted: Sat Oct 27, 2018 4:53 pm    Post subject: Re: 1975 ford 3400 cab heat help Reply to specific post Reply with quote
Do it just like the factory would do if it had a factory cab: Water return will be #9 at the link below, this is the water pump inlet. The hot water supply will be a port between the two rearmost intake manifold attaching bolts. If for some reason there is no plug there, remove the manifold and drill and tap your own 3/8" NPT port. This is very easy to do with an aluminum manifold.
Water return plug
66ford3000
PostPosted: Sat Oct 27, 2018 4:59 pm    Post subject: Re: 1975 ford 3400 cab heat help Reply to specific post Reply with quote
Thank you! I deff appreciate all of the information it deff helps me alot
Tina1510
PostPosted: Sun Jan 20, 2019 6:30 pm    Post subject: Re: 1975 ford 3400 cab heat help Reply to specific post Reply with quote
