TO35 water pump
Eric Mellinger
PostPosted: Tue Nov 13, 2018 6:02 am    Post subject: TO35 water pump Reply to specific post Reply with quote
My water pump is leaking and I need a new pump. I'd like to buy just a new pump and use the old pulley. However, I cannot figure out how the pulley comes apart from the pump. How does the pulley come apart from the pump?
steve19438
PostPosted: Tue Nov 13, 2018 6:50 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
If my memory is not too faded the pulley is pressed on the pump. usually something breaks when trying to separate them. if my memory is faded someone will correct me.
Richard L
PostPosted: Tue Nov 13, 2018 7:18 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
Eric, why don't you rebuild your water pump? Then you know it will fit back on there. They are not hard to rebuild.
jturn36178
PostPosted: Tue Nov 13, 2018 8:25 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
For sure on breaking that pulley when removing.
Even if you rebuild from a kit you must remove the pulley.
My dad sold these for 50 years and I remember breaking a bunch of pulleys. So find out what the proper way to remove pulley before proceeding.
Jim
Eric in Sonoma, Ca
PostPosted: Tue Nov 13, 2018 9:08 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
I'd like to rebuild it but I cannot figure out how to remove the pulley and disassemble. It appears as though the pulley screws onto the pump. I tried to unscrew the pulley but I was afraid of breaking something.
Does anyone have a diagram of how this pump is disassembled?
hymie2lt
PostPosted: Tue Nov 13, 2018 9:29 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
do you have the gas or diesel model? I am thinking you have the Diesel model if you feel it will unscrew? Diesel should have a threaded pump shaft....but that doesnt mean the pulley or hub is threaded.
Wayne
steve19438
PostPosted: Tue Nov 13, 2018 9:32 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
for Z-134 gasoline engine.
55TO35Deluxe
PostPosted: Tue Nov 13, 2018 11:45 am    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
CVPost-Eric Mellinger wrote:
(quoted from post at 07:02:20 11/13/1Cool My water pump is leaking and I need a new pump. I'd like to buy just a new pump and use the old pulley. However, I cannot figure out how the pulley comes apart from the pump. How does the pulley come apart from the pump?
My gas TO35 pulley was pressed on. Easier just to get a new pump from here. The pulley lined up fine just like the old one.
Eric in Sonoma, Ca
PostPosted: Tue Nov 13, 2018 2:38 pm    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
Thanks for the advice. If I can take the pump apart without breaking it, i'll rebuild it. If I break it then i'll buy a new one
54FergieTO30
PostPosted: Tue Nov 13, 2018 7:45 pm    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
CVPost-Eric in Sonoma, Ca wrote:
(quoted from post at 15:38:09 11/13/1Cool Thanks for the advice. If I can take the pump apart without breaking it, i'll rebuild it. If I break it then i'll buy a new one
Exactly what I said. Exactly what I did and ended up buying a new one.
Eric in Sonoma, Ca
PostPosted: Thu Nov 15, 2018 12:58 pm    Post subject: Re: TO35 water pump Reply to specific post Reply with quote
I broke the pulley while disassembling. I'll be buying a new pump. Thank you for all of your help. Eric
