1800 won't come out of gear
chas036
PostPosted: Sat Nov 17, 2018 11:26 am    Post subject: 1800 won't come out of gear Reply to specific post Reply with quote
My clutch plate is seized to the flywheel, so I put the tractor in reverse and started it trying to back it out of a shed. It started and backed out of the shed but the clutch still would not release. My problem now is I can't get it out of reverse. No matter how hard I try, it will not come out of gear. Does anyone have any suggestions?
P I Pete
PostPosted: Sat Nov 17, 2018 11:44 am    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
Is it parked on a hill so there is pressure on the gears? If so, jack one wheel while the is wheel chocked, and see
if that will help.
Pete
chas036
PostPosted: Sat Nov 17, 2018 12:19 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
That did the it. jacked it up, wiggles the wheel a little and it popped out of gear and into natural. NOw I have to use my come along to winch back into the shed. Thanks for the help!!!!
J. Schwiebert
PostPosted: Sat Nov 17, 2018 2:45 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
Why don't you put it in a low gear and drive it in the shed?
Olliejunkie
PostPosted: Sat Nov 17, 2018 4:35 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
CVPost-J. Schwiebert wrote:
(quoted from post at 15:45:21 11/17/1Cool Why don't you put it in a low gear and drive it in the shed?
Start it in gear and jab the breaks several times with the clutch down if you have enough room.
MNGB
PostPosted: Sat Nov 17, 2018 4:51 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
Olliejunkie wrote:
(quoted from post at 17:35:41 11/17/1Cool
That's what I did when the "B" Farmall
GB in MN
Olliejunkie
PostPosted: Sat Nov 17, 2018 6:54 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
MNGB wrote:
(quoted from post at 17:51:44 11/17/1Cool
GB in MN
Could try pulling it in gear with clutch down too.
Don't give up to fast. It hasn't been stuck very long.
Traditional Farmer
PostPosted: Sun Nov 18, 2018 5:05 am    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
I'd get it on a hill where I could get it cranked in 5th gear then drive it around with the clutch pedal depress it'll probably pop loose.
chas036
PostPosted: Sun Nov 18, 2018 2:43 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
I finally got it back into the shed and out of the weather by putting it in first gear and using the starter motor to turn over the engine and move the tractor a little at a time. It took me 4 hours because after 30 sec, I had the recharge the battery for 30 min, but it worked .
I can't really take it out into the yard or field to try anything else because everything here is so saturated that I will put ruts everywhere and probably get stuck in the mud.
I was reading in another blog that someone suggested jacking up one wheel and blocking the other. Then start it in high gear and hit the brake on the moving wheel tryong to pop the clutch free. Has anyone tried this before?
Olliejunkie
PostPosted: Sun Nov 18, 2018 6:17 pm    Post subject: Re: 1800 won't come out of gear Reply to specific post Reply with quote
chas036 wrote:
(quoted from post at 15:43:28 11/18/1Cool I finally got it back into the shed and out of the weather by putting it in first gear and using the starter motor to turn over the engine and move the tractor a little at a time. It took me 4 hours because after 30 sec, I had the recharge the battery for 30 min, but it worked .
I was going to suggest jacking up on wheel, put it in high gear with clutch pedal tied down and rocking the tire back and forth. That may work too. Just dont wait to long or you may have to tear it down. Maybe with the fuel shut off on you can bump starter with clutch depressed in high gear.
