3910 Hydraulic Filter
BlueSteel
PostPosted: Sat Nov 17, 2018 5:11 pm    Post subject: 3910 Hydraulic Filter Reply to specific post Reply with quote
Just realized I don't have a hydraulic filter and was changing a brake rod seal and they rear axle/hydraulic fluid. I've replaced the seal and drained the fluid, will it be fine without any fluid until I can get the filter? Hopefully NAPA has one.
Destroked 450
PostPosted: Sat Nov 17, 2018 6:41 pm    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
It'll be fine setting there until you get a filter and fill the system.
Don't drive it low on fluid.
The filter adapter has a valve in it that stops fluid from leaking out when you screw the filter off, you can fill the axle housing and change the filter later without draining the fluid back out.
BlueSteel
PostPosted: Sat Nov 17, 2018 7:00 pm    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
Destroked 450 wrote:
(quoted from post at 22:41:19 11/17/1Cool
Good to know, thanks for that info. Looks like the filter is below the left foot rest correct?
2hot6ft2
PostPosted: Sat Nov 17, 2018 7:17 pm    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
O'Reilly auto parts stocks WIX hydraulic filters if NAPA doesn't have it. If you have one of those around. That's where i bought mine.
AutoZone and Advance don't stock them here.
Destroked 450
PostPosted: Sat Nov 17, 2018 8:04 pm    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
BlueSteel wrote:
(quoted from post at 22:00:40 11/17/1Cool
Yes that's where it's at.
Texasmark1
PostPosted: Sun Nov 18, 2018 6:06 am    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
Yepper. Plug this into the ebay search engine: Hydraulic Filter Replaces D8NNB486CA D8NNB486EA 231 2310 233 234 250C 2600. Scan down to
the very bottom of the "reliableaftermarketpartsinc" dealer posting for all the Ford tractors this fits and yours will be included.
$17.70 plus fast freight.
RickB
PostPosted: Sun Nov 18, 2018 6:31 am    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
-EA and -CA aren?t the same filter. 84518613 is the current number for the CA suffix filter which is longer than the EA suffix filter. BTW $17 plus shipping is a high price for a will fit aftermarket filter.
Destroked 450
PostPosted: Sun Nov 18, 2018 8:12 am    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
D6NNB486A available on this site for $11.94
Crosses to D8NNB486CA which crosses to
Baldwin BT8504
Carquest 85712
Donaldson P77-9583
Fram P3951
NAPA 1712
Fleetguard HF6115
Wix 51712
BlueSteel
PostPosted: Sun Nov 18, 2018 10:03 am    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
(quoted from post at 12:12:25 11/18/1Cool
Baldwin BT8504
Carquest 85712
Donaldson P77-9583
Fram P3951
NAPA 1712
Fleetguard HF6115
Wix 51712
Thanks! Just picked up the Wix from O'reilly.
Texasmark1
PostPosted: Mon Nov 19, 2018 7:16 pm    Post subject: Re: 3910 Hydraulic Filter Reply to specific post Reply with quote
Most Hyd filters for other tractors run around 30 bucks for the cheapest I've seen. On the ad I posted it said it will do both jobs, the short one and the long one. Seems to be a pretty popular filter.
