1850 with lower 3 Pt leak.
young tractor
PostPosted: Sat Nov 17, 2018 7:45 pm    Post subject: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
Hi guys. I have an 1850 oliver where the lower left connection for the left 3 point arm is leaking gear oil out of rear end. I didn?t realize this is a point that can leak. Is it a seal or o ring? How the heck do I remove it to fix it. I appreciate your advice.
J. Schwiebert
PostPosted: Sat Nov 17, 2018 8:37 pm    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
It is a seal. You will need to either remove the PTO or the hydraulic unit. You have a book? Questions? e-mail is open.
young tractor
PostPosted: Sat Nov 17, 2018 9:14 pm    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
Ok thanks. I need to remove the pto anyway in order to put new seals in it. I?m sure I?ll have more questions as I dig into it this winter. I got this 1850 diesel with a three speed this fall. The engine, 3 speed and injection pump were all rebuilt before I got it. Just need some resealing and paint.
J. Schwiebert
PostPosted: Sun Nov 18, 2018 6:37 am    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
Send me an e-mail anyhow. There are some improvements to make to the PTO while it is out. J,
NYOlivers
PostPosted: Sun Nov 18, 2018 7:51 am    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
J. Can you pass that info along to me as well? I have to pull the pto on my 1850 this winter as well, it is stuck engaged. I will send you a Email also. Thanks
NYOlivers
PostPosted: Sun Nov 18, 2018 7:55 am    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
J. Is correct it is a seal. They are not real hard to change, you just have to remove the pto. I have the part numbers for the seals and gaskets you will need. If you want to Email me xc700awk@roadrunner.com I can pass them along to you. Do you have a service manual?
young tractor
PostPosted: Mon Nov 19, 2018 8:05 pm    Post subject: Re: 1850 with lower 3 Pt leak. Reply to specific post Reply with quote
Nyolivers I sent you an email. I appreciate your help.
