Ford 2N Low Compression
Goto page 1, 2  Next
Randy K. Crump
PostPosted: Mon Dec 03, 2018 6:31 am    Post subject: Ford 2N Low Compression Reply to specific post Reply with quote
Ford 2N engine rebuilt with new pistons, rings, sleeves and valves. I think the compression is too low. Here are my compression test results. I cranked it 5 strokes which is the first number and last number, then placed oil in cylinder which is the last number.
Cylinder 1 - 80 - 105 - 135
Cylinder 2 - 60 - 80 - 100
Cylinder 3 - 60 - 90 - 115
Cylinder 4 - 90 - 115 - 125
Mechanic that did the overhaul no longer available. I have the head off. How do I remove valves and do they need to be ground?
THANKS!
Dollar Bill
PostPosted: Mon Dec 03, 2018 6:39 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
The two middle cylinders may be due to improper head gasket seal. Adding oil during compression test improved 1&4 which points to rings vice valves.
How many hours on the rebuild?
Mike Groom
PostPosted: Mon Dec 03, 2018 7:02 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
As Dollar Bill said,could be a head gasket,also if low hours since the rebuild the rings may not be seated on the two low cylinders,they did increase with oil.
Randy K. Crump
PostPosted: Mon Dec 03, 2018 7:40 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Under 50 hours on rebuild.
Dollar Bill
PostPosted: Mon Dec 03, 2018 8:35 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Rings should have seated in 50 hours. Am wondering if excess ring gap or not staggered properly?
How confident are you regarding test gauge accuracy? If is true, exploratory surgery may be your next move.
souNdguy
PostPosted: Mon Dec 03, 2018 9:32 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Not valves, you can get increasing pressure with oil. Ring issue would be my first thought. I forget, did you say that liners were replaced or not? If not.. Possible measurement issue with rings and liners.
Randy K. Crump
PostPosted: Mon Dec 03, 2018 6:44 pm    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Yes, new pistons and sleeves were installed, all purchased from just 8n's.
Den N Ms
PostPosted: Tue Dec 04, 2018 8:38 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Randy,It could possibly have broken compression rings on cylinders #2 and #3,broken at installation maybe from a (bad ring compressor). Now that you have the head off that kind of puts a stop to a leak down test.You might try and get #2 and #3 to TDC and try and shake them side to side and see if you can feel/see any difference between them and #1 and #4 at TGC.Looser pistons on #2 and #3 would indicate broken rings.
Randy K. Crump
PostPosted: Tue Dec 04, 2018 6:17 pm    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
When I performed the compression test I waited a little bit before releasing the pressure on the gauge and the gauge needle did not move while I waited. For example, if the top number was 100, it maintained that. Is that a good sign?
Den N Ms
PostPosted: Tue Dec 04, 2018 7:05 pm    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Randy,that is your compression gauge holding the pressure,and nothing to do with the condition of your engine.
Randy,did you check the pistons as I stated in my previous post?
Randy K. Crump
PostPosted: Tue Dec 04, 2018 7:20 pm    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Not yet but I plan to.
One mechanic with many years of experience said that when the compression is low with the two middle cylinders (2,3) many times it is the head gasket. I used a metal gasket. There was black carbon around the middle of the gasket between cylinder 2 & 3. Do you think that has any significance?
R Geiger
PostPosted: Tue Dec 04, 2018 8:03 pm    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Could be, did you have the head checked for warpage? When I overhauled one 7 years ago, the head was warped and had to have it milled. You could take it to a machine shop and have it checked and if you do have to have it milled, make sure the valves do not hit the head afterward.
Hobo,NC
PostPosted: Wed Dec 05, 2018 4:40 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Head off check valve seal
Make sure valve to seat is clean
bring piston up to TDC
Valves closed
pour gas are varsoil (mineral sprites) around valve
If valves seal no leakage
If leakage check again they are clean
If clean valves are leaking
Check adjustment if OK valve needs to come out
You can remove manifold and see which valve is leaking.
To late now are maybe not do you remember the first hit on the gauge reading while checking compression. The fist hit is the ability of the valves to seal all the rest are the ability of the cylinder to build compression. You gauge should have a check valve in it, it stores each compression event that's why it will keep building up till you manually bleed it off...
You should not have seen any signs of leakage across the head gasket cylinder to cylinder
Bob
PostPosted: Wed Dec 05, 2018 4:59 am    Post subject: Re: Ford 2N Low Compression Reply to specific post Reply with quote
Dollar Bill wrote:
(quoted from post at 11:35:27 12/03/1Cool Rings should have seated in 50 hours. Am wondering if excess ring gap or not staggered properly?
"Am wondering if excess ring gap or not staggered properly? "
If you are talking about ring end gap (unless DRAMATICALLY large), along with staggering the rings, both those are more or less "old mechanics' wives tales, IMHO.
Ring groove wear is another (BAD) matter.
Note what piston ring GURU Dave Reed has to say about the subject...
http://www.ringspacers.com/tips.htm
Goto page 1, 2  Next
Page 1 of 2
