Corn #127805; heads again
SVcummins
PostPosted: Mon Dec 03, 2018 1:33 pm    Post subject: Corn #127805; heads again Reply to specific post Reply with quote
Looking for what corn header to fit a 7700 John Deere combine
JD Seller
PostPosted: Mon Dec 03, 2018 4:19 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
Any 40 or 90 series corn head will fit on. The only thing to watch for is that the corn head has Level land drives. The straight shaft with sprocket on the end. Side hill and contour master drives would had a bearing on the back shaft and hex shaft for a telescoping shaft top mount on.
SVcummins
PostPosted: Tue Dec 04, 2018 11:08 am    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
What are some model numbers? There are no corn heads at all in this part of the country
IowaJohn
PostPosted: Tue Dec 04, 2018 1:01 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
444,494,are 4row wide,643,693,are 6 row narrow, 644,694,are 6 row wide 844,894,are 8 row wide,893,843 are 8row narrow. Wide is 36-40" rows.narrow is around 30" rows.
DeltaRed
PostPosted: Tue Dec 04, 2018 6:31 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
A 643 would be a 6 row,30" head.
casecollectorsc
PostPosted: Tue Dec 04, 2018 7:57 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
444 is a 4 row wide...such as 38" spacing. Can be narrowed to 36".
SVcummins
PostPosted: Tue Dec 04, 2018 9:02 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
Thanks for the replies . Still not a hundred percent on whether or not I?ll have corn to combine next year or not
JD Seller
PostPosted: Wed Dec 05, 2018 7:40 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
I should have broken the model number down for you. The first number is the number of rows it harvests. The second number is the series of the header. The last number is the row width. 4 = wide row 36-38 inch. 3 = narrow row 28-30 inch. 0 = vary narrow 20 inch.
Some examples. 444 is a four row wide. 643 is a six row narrow. 693 is a newer six row narrow. 1290 header is a 12 row 20 inch head.
OliverGuy
PostPosted: Wed Dec 05, 2018 8:02 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
I ran a 643 on my 7720. A lot of them here in the mid west. Probably not out there. Wide rows don?t bring much at all
tlock0331
PostPosted: Thu Dec 06, 2018 5:33 am    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
SVcummins,
my neck of the woods you can usually find the 6 row narrows in decent shape between 1500-3000, give or take. i dont see many 4 rows a all, and 6 rows are not showing up like they used too.
ill pick one up for ya, but i aint delivering haha
SVcummins
PostPosted: Thu Dec 06, 2018 7:20 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
Will a 7700 run a 6 row head ? Where are you
located?
tlock0331
PostPosted: Thu Dec 06, 2018 8:07 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 22:20:54 12/06/18 ) Will a 7700 run a 6 row head ? Where are you
located?
6600 and up will run a 6 row head, ive seen a lot of 8 row heads on 7700's they didnt look like they struggled, moved along pretty well.
I live kinda between kc and topeka, south a ways.
If you buy that 60 or 720 that is on that big iron sale i would do some trading with ya HAHAH
SVcummins
PostPosted: Thu Dec 06, 2018 10:50 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
Man I?d like to have that loader . It?s going cheap
right now . I will keep in touch as the year goes on .
If I could pick up a corn head cheap I think I?d get
one
tlock0331
PostPosted: Fri Dec 07, 2018 6:28 am    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
SVcummins,
where are you on the planet? relative anyway?
there are several corn heads on big iron and a bunch on auctiontime.
Its also not unheard of to run a row crop head on corn, they are typically cheaper and in some years i like it better if i am not running a lot because it breaks the stalks up a lot more so they decay a lot more and faster.
SVcummins
PostPosted: Fri Dec 07, 2018 7:15 pm    Post subject: Re: Corn #127805; heads again Reply to specific post Reply with quote
Idaho
Post new topic    Yesterday's Tractors Forum Index -> Combines and Harvesters All times are GMT - 8 Hours
