12 V coil
Phil Tibbetts
PostPosted: Wed Dec 05, 2018 3:00 pm    Post subject: 12 V coil Reply to specific post Reply with quote
What is the part number for a 12 volt coil that can be used on a 6 volt distributor? TIA
Pete_5959
PostPosted: Wed Dec 05, 2018 3:29 pm    Post subject: Re: 12 V coil Reply to specific post Reply with quote
Phil do you mean what 12V coil for a 6V system? Pretty sure distributor not voltage sensitive.
r/
Pete in NC
Phil Tibbetts
PostPosted: Wed Dec 05, 2018 3:38 pm    Post subject: Re: 12 V coil Reply to specific post Reply with quote
Seems I read on here a while back if you change system to 12 volts from 6 there is a coil you can get so you don't need to put a resistor in the line to distributor. Maybe I'm wrong, wouldn't be the first time.
tn terry t
PostPosted: Wed Dec 05, 2018 3:41 pm    Post subject: Re: 12 V coil Reply to specific post Reply with quote
CVPost-Phil Tibbetts wrote:
(quoted from post at 19:00:37 12/05/1Cool What is the part number for a 12 volt coil that can be used on a 6 volt distributor? TIA
if your changing to a 12volt system instead of 6 volt I use the napa ic14sb which is a 12volt coil that does not need the external resistor
Phil Tibbetts
PostPosted: Wed Dec 05, 2018 5:56 pm    Post subject: Re: 12 V coil Reply to specific post Reply with quote
Thank you that is what I was looking for.
DeltaRed
PostPosted: Wed Dec 05, 2018 7:23 pm    Post subject: Re: 12 V coil Reply to specific post Reply with quote
Most new coils these days are internally resisted.the box should say so.However a NAPA coil will work but wont look right.If that matters,get an OEM looking coil from Stieners,this site,others.
tn terry t
PostPosted: Thu Dec 06, 2018 5:42 am    Post subject: Re: 12 V coil Reply to specific post Reply with quote
CVPost-DeltaRed wrote:
(quoted from post at 23:23:48 12/05/1Cool Most new coils these days are internally resisted.the box should say so.However a NAPA coil will work but wont look right.If that matters,get an OEM looking coil from Stieners,this site,others.
to go along with the OEM looking alternator Shocked
