53' Ford Jubilee
Goto page 1, 2  Next
rcfarms
PostPosted: Sat Jan 05, 2019 3:06 pm    Post subject: 53' Ford Jubilee Reply to specific post Reply with quote
I was on here some months ago about my jubilee cutting out on me and finding out it was the points, replaced the points back then started up well, but I spun the distributor and it died( didn't realize a hold bolt was loose), but I could never get it to start up again, just puffed smoke, so I thought it was a timing issue(also noted so on here) but also found out no gas was making it to the cylinders. Dry plugs. So I just got back on it today, replaced carb 1 1/4 turn on big screw and 2 turns out on small screw, set timing manually at timing hole 0 TDC (but the rotor is now a different position for No.1 after that dist. spin, don't know if that means anything or not) have spark at plugs, changed ignition switch, checked points gap, distributor dust cap, rotor and dist. cap on correctly, turned on ignition, no start, then it backfired through the exhaust. So, I set the timing again this time 8 degrees BTD, checked everything above, turned over well but never fired up then backfired through the exhaust again. Plugs appear dry so there must be a mis-step somewhere between the fuel uptake and the timing, I'm lost at this point and could use your advice/opinions. Tractor has about 340 hrs on motor. Thanks, Ron
JMOR
PostPosted: Sat Jan 05, 2019 3:10 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
CVPost-rcfarms wrote:
(quoted from post at 19:06:13 01/05/19) I was on here some months ago about my jubilee cutting out on me and finding out it was the points, replaced the points back then started up well, but I spun the distributor and it died( didn't realize a hold bolt was loose), but I could never get it to start up again, just puffed smoke, so I thought it was a timing issue(also noted so on here) but also found out no gas was making it to the cylinders. Dry plugs. So I just got back on it today, replaced carb 1 1/4 turn on big screw and 2 turns out on small screw, set timing manually at timing hole 0 TDC (but the rotor is now a different position for No.1 after that dist. spin, don't know if that means anything or not) have spark at plugs, changed ignition switch, checked points gap, distributor dust cap, rotor and dist. cap on correctly, turned on ignition, no start, then it backfired through the exhaust. So, I set the timing again this time 8 degrees BTD, checked everything above, turned over well but never fired up then backfired through the exhaust again. Plugs appear dry so there must be a mis-step somewhere between the fuel uptake and the timing, I'm lost at this point and could use your advice/opinions. Tractor has about 340 hrs on motor. Thanks, Ron
rotate engine full revolution until ) is back in window, set distributor timing here & rotor will be back where you want it & probably start.
JMOR
PostPosted: Sat Jan 05, 2019 7:38 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
JMOR wrote:
(quoted from post at 19:10:28 01/05/19)
0, not )
rcfarms
PostPosted: Sun Jan 06, 2019 7:40 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
Sorry but I'm a bit confused. I had reset the timing twice (yesterday) since the loose dist.had spun a few months ago. Once at 0 TDC then at 8 degrees before TDC, no start on either but an exhaust backfire, so won't rotating the engine a complete revolution just bring the rotor back to where it is now?
Eman85
PostPosted: Sun Jan 06, 2019 8:59 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
I think what he's trying to say is you have the distributor installed 180 degrees out of time. The cranks turns twice as fast as the distributor.
JMOR
PostPosted: Sun Jan 06, 2019 10:45 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
4 stroke engine. 2 revolutions for complete cycle. The 0 mark will occur twice per cycle, once for cyl #1 TDCC and once for cyl # 4 TDCC. I'm saying you installed distributor for #4 TDCC.
rcfarms
PostPosted: Sun Jan 06, 2019 11:28 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
ok, hoping I understand, it's 180 degrees out of timing, so I need to rotate the engine one more time to 0 mark for the number one cylinder. I guess I should pull the number 1 plug and insert a screw driver (to push out) to be sure I'm at the number 1 TDCC. Thanks, Ron
rcfarms
PostPosted: Sun Jan 06, 2019 11:29 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
I think I understand, thanks, Ron
JMOR
PostPosted: Sun Jan 06, 2019 12:09 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
(quoted from post at 15:28:16 01/06/19) ok, hoping I understand, it's 180 degrees out of timing, so I need to rotate the engine one more time to 0 mark for the number one cylinder. I guess I should pull the number 1 plug and insert a screw driver (to push out) to be sure I'm at the number 1 TDCC. Thanks, Ron
Just because piston is at TDC does not mean it is TDC-Compression, it could be TDC-Exhaust. Gotta be right TDC
jtc
PostPosted: Mon Jan 07, 2019 4:11 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
[quote="CVPost-rcfarms"](reply to post at 16:06:13 01/05/19) install electronic ing.
View user's profile AIM Address
showcrop
PostPosted: Mon Jan 07, 2019 6:28 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
RCfarms you should be getting gas to the cylinders regardless of timing. You may want to check gas at float bowl drain.
rcfarms
PostPosted: Mon Jan 07, 2019 8:13 am    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
ok, I'll check it, and thanks for all of the help.
Jim L WA
PostPosted: Mon Jan 07, 2019 4:59 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
Hold your finger in the number one spark plug hole and bump the engine over until you feel compression. Don't rely on sticking a screwdriver in there. Don't throw any more new parts at it (especially electronic ignition). I would even put the old carburetor back on, there was nothing wrong with it. Firing order is 1,2,4,3. clockwise.
Tall T
PostPosted: Mon Jan 07, 2019 6:34 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
RC,
Here's how I "static" time an OHV engine like your Jubilee.
Here's how I've done it.
If your valve cover is off you can tell when #1 piston is coming up on its compression stroke, when you see the intake valve closing: i.e., the rocker arm is releasing the INTAKE valve spring, letting it come up and close.
At that point I stand a tall slim screwdriver up in the plug hole, using a string or something to keep the screwdriver vertical so that it doesn't bind at the plug hole. this way you can see exactly when the piston reaches Top Dead Center and exactly when the piston begins to descend. But if your valve cover is on, use your finger or a compression guage to plug up #1 spark plug hole. When the piston is coming up on the compression stroke, you will hear or feel air trying to escape past your finger or see action on the compression guage -- then enter the screwdriver method.
Next, after confirming that your rotor is pointing at #1 on the dist cap, and your point gap is properly set, loosen the dist clamp bolt, and turn the dist a little CLOCKWISE to position the point rubbing block on the closest dist cam flat spot , just to the right of the nearest high shoulder, where it will then be ready to climb to that high point as the rotor approaches.
With the cap off of course, turn the key on
Rotate the distributor slightly COUNTERCLOCKWISE
(because the rotor runs CLOCKWISE) just until you see the points begin to open and see and hear a SPARK. Tighten the dist clamp bolt and quickly turn the key off.
Now you know that #1 piston is getting a spark for it's next downward power stroke and if all else is right (wires 1243 Clockwise on the cap) then it will start.
You can fine time it later.
rcfarms
PostPosted: Wed Jan 09, 2019 1:38 pm    Post subject: Re: 53' Ford Jubilee Reply to specific post Reply with quote
Thanks, I will try your method.
Goto page 1, 2  Next
Page 1 of 2
