Serial #
Jona
PostPosted: Tue Dec 11, 2018 12:01 pm    Post subject: Serial # Reply to specific post Reply with quote
What year a D 17 is the serial number 41098 ? M, and the serial number D 17 56 511-Z, and what does that M and z stand for at the end ?
With the paint I hope I got the numbers right .
Aaron SEIA
PostPosted: Tue Dec 11, 2018 12:22 pm    Post subject: Re: Serial # Reply to specific post Reply with quote
Those are engine serial numbers. The M and Z refer to compression ratios. Tractor serial number is on the left side bellhousing just above the frame rail.
AaronSEIA
Jona
PostPosted: Tue Dec 11, 2018 12:31 pm    Post subject: Re: Serial # Reply to specific post Reply with quote
What year are the two serial numbers I sent ?
Aaron SEIA
PostPosted: Tue Dec 11, 2018 1:57 pm    Post subject: Re: Serial # Reply to specific post Reply with quote
I don't know. I don't think anyone has an engine serial number chart.
AaronSEIA
Butch(OH)
PostPosted: Wed Dec 12, 2018 5:39 am    Post subject: Re: Serial # Reply to specific post Reply with quote
As Aaron said the tractor number is stamped on the left side of the clutch housing above the steering shaft andframe rail. It should start with D17 and end with a D if it is a diesel. IF 41098 is in that location it is a 1962 but I dont know about the M means.
grader man 1965
PostPosted: Sat Dec 22, 2018 11:30 am    Post subject: numbers stamped behind the carb. 17-5238-m what is it? Reply to specific post Reply with quote
Aaron SEIA wrote:
(quoted from post at 13:22:26 12/11/1Cool Those are engine serial numbers. The M and Z refer to compression ratios. Tractor serial number is on the left side bellhousing just above the frame rail.
AaronSEIA
grader man 1965
PostPosted: Sat Dec 22, 2018 11:32 am    Post subject: Re: numbers stamped behind the carb. 17-5238-m what is Reply to specific post Reply with quote
Its an Allis Chalmers Road grader, trying to figure out what engine it has.
Thank you....
grader man 1965
Thank you....
DrAllis
PostPosted: Sat Dec 22, 2018 2:46 pm    Post subject: Re: numbers stamped behind the carb. 17-5238-m what is Reply to specific post Reply with quote
That G-226 engine is the same as a D-17 tractor and would be considered a 1958 model year build with that low serial number. The "M" code is 7.25 to 1 compression ratio, which was for gasoline fuel, not LPgas. A G-226 is not to be confused with the W-226, which was used in the WD-45 tractor. They are similar in many respects, but they ain't the same. The blocks and crankshafts are different between the two engines.
DrAllis
PostPosted: Sat Dec 22, 2018 2:48 pm    Post subject: Re: numbers stamped behind the carb. 17-5238-m what is Reply to specific post Reply with quote
I am referring to engine serial number 17-5238-M for my response.
