white 2-155 parking brake
Hustler1
PostPosted: Sat Dec 15, 2018 4:52 pm    Post subject: white 2-155 parking brake Reply to specific post Reply with quote
this also a white page? Parking brake linkage works but brake doesn't engage. Have not taken off shift cover yet. according to parts it is buried.anyone worked on this?
rrlund
PostPosted: Sat Dec 15, 2018 5:58 pm    Post subject: Re: white 2-155 parking brake Reply to specific post Reply with quote
Ya,it's down there. The bolt that holds the pivot just screws in to the side of the casting. There's nothing that really holds it on the outside,so it can be prone to shearing off. I was just getting ready to start filling silo with my 135 when it broke. We ended up taking everything right out of mine. I put a bolt in the hole that the rod goes down through to keep the dirt out of it. It's so tight in there that I couldn't even get my arm down past the gears. My son got his down in there and got a wrench on the bolt at the bottom end of that rod. We put a bolt through the hole at the top and turned it up there with a pipe wrench.
Hope beyond all hope that that bolt didn't break in yours. There's no room to get in there to drill it out. Somebody told me that you have to pull the engine,pop out a soft plug and drill it out with a long left handed bit. I asked the mechanic at the old Oliver/White dealer about it and he said he never fooled with one,he just knew that in his opinion,everything else had to come out of the transmission to get to anything.
All the guts for mine are in a cabinet in the shop. Wish I had better news.
rrlund
PostPosted: Sun Dec 16, 2018 7:38 am    Post subject: Re: white 2-155 parking brake Reply to specific post Reply with quote
To get to that to check it,pull up the floor mat,unbolt the cab floor and take it up. There's a dozen or so 3/8 bolts holding the transmission cover on. You'll have to take off a few hydraulic lines so you can lift the cover off.
Hustler1
PostPosted: Sun Dec 16, 2018 4:40 pm    Post subject: Re: white 2-155 parking brake Reply to specific post Reply with quote
I have the engine and 3 speed out to rebuild 3 speed, going to pull cover off next when I get time , maybe later in the week, Thanks!
Hustler1
PostPosted: Mon Jan 07, 2019 12:33 pm    Post subject: Re: white 2-155 parking brake Reply to specific post Reply with quote
Finally got cover off , pivot bolt is missing not sure if broke off , might have to look at tomorrow, got parts for 3 other tractors so they come first, thanks!
