Fuel Gauge reading backwards?
Tim Hosmer
PostPosted: Tue Dec 18, 2018 6:00 pm    Post subject: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I bought a replacement gauge cluster for my ford 3000. Everything works fine except the fuel gauge. It's reading backwards. I pulled the sending unit and it moves the needle just fine only in the wrong direction. I tried switching the wires on back of the gauge, but that only pegs it out on empty. Anyone else experienced this?
Tim Hosmer
PostPosted: Tue Dec 18, 2018 6:23 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
Any ideas on how to fix it?
OBwan
PostPosted: Tue Dec 18, 2018 6:49 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
Until more knowledgeable gurus respond... I would think if you grounded the terminal to the sender it should peg full. Determine if its the gauge or the sender and replace as needed.
sunbeam
PostPosted: Tue Dec 18, 2018 6:51 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
Try swapping the leads on the gauge your tractor is wired Neg ground???
Tim Hosmer
PostPosted: Tue Dec 18, 2018 7:11 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I tried swapping the wires and it pegs empty...
JMOR
PostPosted: Wed Dec 19, 2018 12:41 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I would investigate a mis-match between gauge & sender, as some senders are at max resistance full , while others are at max resistance empty.
john in la
PostPosted: Wed Dec 19, 2018 4:23 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I would say JMOR has this right.
You replaced the gauge or sending unit and did not get a match for the other.
I will really go out on a limb and guess the gauge is the problem as I "think" most fords work with a peg out on full gauge.
Ultradog MN
PostPosted: Wed Dec 19, 2018 5:27 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I don't have an answer for you but I do
wish I had a tractor that the more I
worked it the fuller the tank got.
Eman85
PostPosted: Wed Dec 19, 2018 6:45 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
https://forums.yesterdaystractors.com/viewtopic.php?t=1245279
In this thread there are ohm specs for the sending unit.
JL Ray
PostPosted: Fri Dec 21, 2018 11:30 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
Take a paint maker, and put a "F" where the "E" is and put a "E" were the "F" is. There done.....
Merry Christmas.
Tim Hosmer
PostPosted: Fri Dec 21, 2018 3:30 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
CVPost-jl ray wrote:
(quoted from post at 12:30:14 12/21/1Cool Take a paint maker, and put a "F" where the "E" is and put a "E" were the "F" is. There done.....
Merry Christmas.
Lol... I think that's what I'll do for now.
sotxbill
PostPosted: Mon Dec 24, 2018 9:11 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
"E" stands for ENOUGH fuel... 'F' stands for FILL IT NOW!
twingum
PostPosted: Wed Oct 23, 2019 2:20 pm    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
I know this is an old thread, but just in case a solution was found. I installed a new sending unit and now the gauge reads backwards, i.e., as the tank empties the needle moves towards full.
lastcowboy32
PostPosted: Fri Oct 25, 2019 8:42 am    Post subject: Re: Fuel Gauge reading backwards? Reply to specific post Reply with quote
Post a video of your tractor on Facebook.
Caption the video that you have invented a new engine that captures CO2 from the air as it runs to create its own fuel.
Go further to say that this technology can reverse Climate Change, but the oil industry is hiding it.
Sit back and wait for it to go viral.
You may as well have some fun with this.
