AC IB Clutch Noise
Rimshot
PostPosted: Sat May 12, 2007 9:49 am    Post subject: AC IB Clutch Noise Reply to specific post Reply with quote
A friend of mine has alittle IB. When you let the clutch out there is a noise---kinda whiny-not a growl. When you push the clutch back in it goes away. What is it? I thought maybe the throw-out bearing--if not that what could it be? Thanks
steve(ill)
PostPosted: Sat May 12, 2007 5:08 pm    Post subject: Re: AC IB Clutch Noise Reply to specific post Reply with quote
crawl under the tractor and look up thru the egg shaped hole. there is a grease zerm on the bearing-- put 4-5 shots in that and see what happens.
chalmersbob
PostPosted: Sun May 13, 2007 4:09 pm    Post subject: Re: AC IB Clutch Noise Reply to specific post Reply with quote
sounds like noise coming from the trany. if it were the throwout bearing it would make the noise when the clutch is depressed. Bob
