Case 480f backhoe injector pump leaking at throttle shaft
wallacemerritt
PostPosted: Thu Dec 20, 2018 2:15 pm    Post subject: Case 480f backhoe injector pump leaking at throttle shaft Reply to specific post Reply with quote
How difficult is it to replace the seal in the throttle shaft. Its leaking pretty good. Can I pull just the top cover off or do I need to remove the whole pump from the machine? Its a CAV pump. Thsnks
Dieseltech
PostPosted: Thu Dec 20, 2018 3:03 pm    Post subject: Re: Case 480f backhoe injector pump leaking at throttle shaf Reply to specific post Reply with quote
While it can be repaired on engine, my experience is other leaks show up soon after and pump will need to come off anyway. Why I stopped doing "patch jobs", after a few bite your backside it's not easy trying to explain to the owner why it's leaking again. I now will only reseal the complete pump, or won't touch it.
wallacemerritt
PostPosted: Thu Dec 20, 2018 9:25 pm    Post subject: Re: Case 480f backhoe injector pump leaking at throttle shaf Reply to specific post Reply with quote
Ive never resealed an injector pump before, it dosent seem like it would be to big of a job other then getting it off. After its pulled and Ive replaced all the seals and its reinstalled is there a process to prime the pump?
Dieseltech
PostPosted: Fri Dec 21, 2018 5:01 am    Post subject: Re: Case 480f backhoe injector pump leaking at throttle shaf Reply to specific post Reply with quote
Getting it off-on is the easy part. I always bench test pumps after repair to make sure the governor, transfer pump, advance, etc. all work correctly with NO leaks. Depending on how far down it's taken apart there are special tools needed also. I take them completely apart to inspect everything.
