Author |
Message |
AdamEichele Regular
Posted: Wed Dec 26, 2018 6:09 pm Post subject: 82S Mower on WD45 |
I am running into a issue with my AC 82S Mower. The outer shoe with the ledger plate is shot. I tried buying a new Holland brand new shoe but the bar is to thick for it. The old shoe was wore out causing the mower to plug up at the end. Does anyone have a outer shoe for sale with the ledger plate in for sale? I would send the check in the mail and pay for shipping.---adam |
Back to top |
Traditional Farmer Tractor Guru
Posted: Wed Dec 26, 2018 6:49 pm Post subject: Re: 82S Mower on WD45 |
I have a bunch of Twin wheel drive mowers for parts might even have a NOS end.Couple questions though what type of end section are you using on your sickle assembly? To keep it from plugging you need to run a double or split section.Also do you have the slide on the end shoe to hold it up? |
Back to top |
Bob Bancroft Tractor Guru
Posted: Thu Dec 27, 2018 2:41 am Post subject: Re: 82S Mower on WD45 |
You can, after a fashion, rivet a new ledger plate to the end shoe. Although, I had to tack weld mine to keep it tight.
I did take a NH skid and adapt it to fit the AC shoe, and I have the skid dropped as far as it will go. |
Back to top |
Brian G. NY Long Time User
Joined: 02 Dec 2007 Posts: 769 Location: Upstate New York
Posted: Thu Dec 27, 2018 7:12 am Post subject: Re: 82S Mower on WD45 |
CVPost-Bob Bancroft wrote: | (quoted from post at 11:41:35 12/27/1 You can, after a fashion, rivet a new ledger plate to the end shoe. Although, I had to tack weld mine to keep it tight.
I did exactly as Bob did.
I never installed one of those split sections although I have been considering it.
With the hold downs adjusted properly and sharp sections, I rarely ever have a problem. |
Back to top |
Posted: Thu Dec 27, 2018 7:16 am Post subject: Re: 82S Mower on WD45 |
BTW, I have had a bigger problem with that special ledger plate on the inner shoe.
I had to devise a custom shim to bring it up where it meets the knife so it wouldn't "clog up".
It takes quite a lot of patience to get one of these mowers set up right but when you do it is a pleasure to use. |
Back to top |
Posted: Thu Dec 27, 2018 8:25 am Post subject: Re: 82S Mower on WD45 |
I like wise have had to amend that inner ledger plate holder.
I probably would have been just as far ahead to start with some flat stock, rather than starting with the NH skid, for the price of it!
I did put one of those knife-and-a-half's out on the end. It helped. My problem is I mow edges and ditches with this mower, so it's alternately a dozer, rock picker, wire cutter, brush cutter/chomper, you name it! |
Back to top |
AdamEichele Regular
Posted: Thu Dec 27, 2018 8:45 am Post subject: Re: 82S Mower on WD45 |
I do use a double split end section. It helps but the new Holland shoe doesn't line up. I would be interested buying one off of someone. my number is 7012024196. Otherwise I will have to cut up the new Holland shoe. |
Back to top |
AdamEichele Regular
Posted: Thu Dec 27, 2018 2:21 pm Post subject: Re: 82S Mower on WD45 |
I am interested in buying one if you have it. 7012024196. |
Back to top |
hd6gtom Tractor Guru
Posted: Sat Dec 29, 2018 5:03 pm Post subject: Re: 82S Mower on WD45 |
If he doesn't have 1, I know I have one on a mower out back. I do have quite a few used parts for those
mowers. |
Back to top |
AdamEichele Regular
Posted: Sat Dec 29, 2018 5:29 pm Post subject: Re: 82S Mower on WD45 |
Yes as long as it will fit the 82S bar and has the ledger plate. My CP# is 7012024196. I can send a check to pay for shipping as well. I live in central nd. Look forward to working with you---adam |
Back to top |
