175 Allis Hydraulics
LTFT
PostPosted: Tue Jan 01, 2019 5:28 pm    Post subject: 175 Allis Hydraulics Reply to specific post Reply with quote
How warm should the torque tube get right above the power director? Mine get rather warm.
Bob Bancroft
PostPosted: Tue Jan 01, 2019 5:45 pm    Post subject: Re: 175 Allis Hydraulics Reply to specific post Reply with quote
On a hot day, working the tractor, everything can get quite hot. That's why that tin shield is there on the left side of the tranny- so you don't burn your leg.
DrAllis
PostPosted: Wed Jan 02, 2019 5:14 am    Post subject: Re: 175 Allis Hydraulics Reply to specific post Reply with quote
When working in the field you will not be able to hold your hand on it. 180 degrees isn't too hot. Put your hand on the engine block on that same day and see how hot it is.
LTFT
PostPosted: Wed Jan 02, 2019 5:35 pm    Post subject: Re: 175 Allis Hydraulics Reply to specific post Reply with quote
Thank you both. I will quit thinking something is wrong and see if I can find a shield. Never had one since I've had it.
DrAllis
PostPosted: Thu Jan 03, 2019 5:19 am    Post subject: Re: 175 Allis Hydraulics Reply to specific post Reply with quote
CVPost-LTFT wrote:
(quoted from post at 18:35:13 01/02/19) Thank you both. I will quit thinking something is wrong and see if I can find a shield. Never had one since I've had it.
****** The only heat shield there ever was is to the LEFT side of the transmission housing, bolted to the left platform and to three bolts on the shift cover. not directly ahead of the gearshift and under the steering wheel like you described.
