Restoring Farmall Model A
bobo641
PostPosted: Thu Jan 03, 2019 5:11 pm    Post subject: Restoring Farmall Model A Reply to specific post Reply with quote
I am restoring a Farmall model A. I would like to know what is the correct way to mount the rear rims. valve stems in or out.I would like to mount stems out but the it seems like the center and weights stick out way to far. I could really use some advice from you tractor guys. I have enclosed some picture. Thanks
MtMan
PostPosted: Thu Jan 03, 2019 8:01 pm    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
I'm not near my A as of right now. But if you have the wheels off for any reason make sure you get them back on the side that they are supposed to be on. one wheel is pressed steel and only about 1/4' thick. That goes on the left side. The other wheel is cast steel and is about 1 1/2" thick and goes on the right side. This is to balance the weight of the off set tractor. Good Luck
old
PostPosted: Fri Jan 04, 2019 10:50 am    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
No correct way it all depended on how wide they wanted the tractor to sit for different jobs. Centers can also be flipped to space the wheel in or out more
Pappy
PostPosted: Sat Jan 05, 2019 3:37 am    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
Don't own an "A" Farmall, but would not the heavier wheel go on the left side because the driver is on the right side.
MtMan
PostPosted: Sat Jan 05, 2019 8:18 am    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
The thicker wheel goes on the right side of the tractor.
Dennis K (WA)
PostPosted: Sat Jan 05, 2019 9:47 am    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
MtMan has it. Cast hub goes on the right to off set the engine/trans on the left.
Dennis
Secret Squirrel
PostPosted: Thu Jan 10, 2019 9:32 am    Post subject: Re: Restoring Farmall Model A Reply to specific post Reply with quote
If you have them on the closest setting turn the valve stems out. In can drag on the tractor and become damaged.
