What is the final drive ratio of a 941 row crop?
warbaby
PostPosted: Sat Jan 12, 2019 10:19 am    Post subject: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
Hi,
I know I have seen it somewhere, but cant find it now! What is the actual rear axle ratio on a row-crop 01 series tractor after it passes through and is altered by the set of bull gears to the rear tires?
What is the reduction (or the number of teeth on each gear in the pair) value of the gearset?
Thank You!
Bob
PostPosted: Sat Jan 12, 2019 10:59 am    Post subject: Re: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
15 teeth driving 32 teeth, .46875 to 1.
Bob
PostPosted: Sat Jan 12, 2019 11:02 am    Post subject: Re: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
I stated that backwards, should be 2.133 to 1.
warbaby
PostPosted: Sat Jan 12, 2019 12:35 pm    Post subject: Re: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
Thank You Bob!
Sooo... the ring and pinion in this tractor are 43 and 6 teeth, 43 divided by 6 = 7.17 so the ratio coming out of the differential and going down the axle shaft into the 15 toothed bull gear is 7.1:1. The bottom 32 toothed gear divided by the upper 15 toothed gear is 2.133:1.
7.17 MULTIPLIED by 2.133 = 15.29361, so the final ratio at the wheel is 15.29:1?
THAT seems awfully low!
warbaby
PostPosted: Sat Jan 12, 2019 12:55 pm    Post subject: Re: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
maybe it should be 7.17 + 2.13? That would equal 9.3, and a final ratio of 9.3:1 sounds far more reasonable than 15.29:1!
JMOR
PostPosted: Sat Jan 12, 2019 1:00 pm    Post subject: Re: What is the final drive ratio of a 941 row crop? Reply to specific post Reply with quote
CVPost-warbaby wrote:
(quoted from post at 16:55:39 01/12/19) maybe it should be 7.17 + 2.13? That would equal 9.3, and a final ratio of 9.3:1 sounds far more reasonable than 15.29:1!
not add, multiply.
