Farmall m stroker
Dkranawetter2121
PostPosted: Tue Jan 08, 2019 5:34 pm    Post subject: Farmall m stroker Reply to specific post Reply with quote
Where is the best place to get a stroke crank made for a farmall m and what is the max stroke I can go without cutting the block and what is the max bore I can go on a 47 m I am located In southeast Missouri
Dblair
PostPosted: Wed Jan 09, 2019 2:35 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
murphys motor service is going to be the easiest but the M block might not be what you want to start the project with . get a 400 or 450 block and you can knock the sleeves out and put 4.25 pistons in it or bore it to 4.310 easily , add a 6.75 stroke and have 394 cu.in with over 100 hp .
20MuleTeam
PostPosted: Wed Jan 09, 2019 3:13 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
Yes, but why not 7.25 & hard block 1/2 way up. Had good results with this from the 400/450 block.
VicS
PostPosted: Thu Jan 10, 2019 4:07 am    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
What stroke do you start getting into the oil gallery? Saw inside one 25 years ago, had copper oil lines going around inside. Must have been bored and sleeved to 4 1/2 or bigger.
20MuleTeam
PostPosted: Thu Jan 10, 2019 9:18 am    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
Don't know, not an engine builder, but I did replace the head gasket & found the 2" stroke, no sleeve bare block. Temp is excellent with 1/2 hard block.
535353m
PostPosted: Thu Jan 10, 2019 10:35 am    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
my buddy does 5.125 x 8 works well,all hard block no head gasket,ready thread and more tricks.
20MuleTeam
PostPosted: Thu Jan 10, 2019 2:01 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
Wow, that's 660 cubes. I've heard of off centering the holes to make room, but holey moley!
LCB
PostPosted: Thu Jan 10, 2019 3:40 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
I have M with that stoker kit in it ready to get on and go pull. Asking 10500.
LCB
PostPosted: Thu Jan 10, 2019 3:41 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
Phone number 618 664 3732
Sweeper
PostPosted: Fri Jan 11, 2019 6:27 am    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
I have one for sale. Wife said I had to sale one. It's a 4.350 X 7.500, L P head MSD. Has won at Tunica. Includes 20 100# weights.Call Jim Broome, 901-494-8184
535353m
PostPosted: Sat Jan 12, 2019 9:02 am    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
ya,it is a lot of machining and not much cast left,2000 rpms,on that one,but little smaller her runs 2800 and has power !!!!!!!!!!!!!!!!!
molinepuller
PostPosted: Wed Jan 23, 2019 2:11 pm    Post subject: Re: Farmall m stroker Reply to specific post Reply with quote
I like to build IHC M with a 4.500 stroke 7.500 stroke makes good power don't have to worry about sleeves leaking. I do all machine work in house. Located east of St. Louis Mo.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
