Oliver oc 3 questions
mikewood869
PostPosted: Thu Jan 10, 2019 10:29 am    Post subject: Oliver oc 3 questions Reply to specific post Reply with quote
Just wondering about an Oliver oc 3 crawler tractor with dozer blade and pto. The crawler has a mag. Supposedly the last time it ran was in September on starting fluid and before that was god knows when. At the moment the starter is of the tractor. The wiring is junk and the belt pulley is gone. How hard would it be to pull start the tractor and run it for a minute (probably should just stick a bar into the flywheel and turn it over by hand first?)? Have no clue about a wiring diagram. If the starter was to come back, would the tractor run on 12 volts? For fuel tank, I have a one gallon snowblower tank.
mikewood869
PostPosted: Thu Jan 10, 2019 10:31 am    Post subject: Re: Oliver oc 3 questions Reply to specific post Reply with quote
Sorry I meant the pulley on the motor was taken off, not the belt pulley.
rrlund
PostPosted: Thu Jan 10, 2019 12:16 pm    Post subject: Re: Oliver oc 3 questions Reply to specific post Reply with quote
With a mag,you don't need a battery to start it. A mag makes it's own electricity. A 12 volt to turn the starter won't hurt a thing. I'd unhook the wires to the generator and regulator before I tried it is all.
RBoots
PostPosted: Thu Jan 10, 2019 7:13 pm    Post subject: Re: Oliver oc 3 questions Reply to specific post Reply with quote
Some had a water pump, some were thermo-
siphon cooling. Probably not the best to
run either for too long without the fan
or water pump turning.
Ross
Dblair
PostPosted: Fri Jan 11, 2019 2:49 pm    Post subject: Re: Oliver oc 3 questions Reply to specific post Reply with quote
put it in 3rd gear and give it a yank . done it many a time .
