PTO driven snowblower keeps shearing pins
Goto page 1, 2  Next
YooperJD60
PostPosted: Thu Jan 10, 2019 10:50 am    Post subject: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
I keep shearing a pin on the snowblower and can't figure out why. It doesn't take much of a load in the blower and It shears. At first I thought maybe I was going too fast,but even at slower speeds it shears. The blower seems to operate well otherwise. I can rotate the shaft by hand and it feels smooth and easy.
Bob
PostPosted: Thu Jan 10, 2019 10:55 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
Over time the shearbolt holes get wallowed out/tapered, so the shearbolt gets pushed on unevenly, making it break much easier than when the holes are straight and true.
YooperJD60
PostPosted: Thu Jan 10, 2019 11:29 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
That could be the case....the shear pin is 1/4" and fits loose...maybe I should drill it out to 5/16" or drill a new hole?
DIM
PostPosted: Thu Jan 10, 2019 11:44 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
I had that problem on my snow blower. I had repaired the drive shaft and did not weld the u joints back in line.
old
I would drill out the hole it already has to the next size up and give that a try unless the shaft is real small
rrlund
PostPosted: Thu Jan 10, 2019 12:37 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
Roger in Iowa
PostPosted: Thu Jan 10, 2019 1:12 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
Was the original a special bolt? Should not fit loose. Was the original a metric bolt?
Drill new 1/4" holes, both pieces.
YooperJD60
PostPosted: Thu Jan 10, 2019 2:05 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
It also has a keyway...does this sound right? When the shear pin breaks then the PTO shaft keeps spinning or flys off and I also lose the keyway
stevob671
PostPosted: Thu Jan 10, 2019 3:46 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
So is it supposed to have a key and the bolt is just to hold it from sliding off? Do you have a parts diagram you can refer to or dig up online?
If you got the make/model handy maybe someone can come up with more info also.
kevinj54
PostPosted: Thu Jan 10, 2019 4:05 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
CVPost-YooperJD60 wrote:
(quoted from post at 18:05:05 01/10/19) It also has a keyway...does this sound right? When the shear pin breaks then the PTO shaft keeps spinning or flys off and I also lose the keyway
Sounds like your shaft is too long.
You need to post some pics of this, I do not think you are looking at a shear bolt.
Leroy
PostPosted: Thu Jan 10, 2019 9:58 pm    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
A shear bolt would NOT have a keyway in shaft as that would defeat the reason for the shear bolt, A shear bolt would shear from turning and a key would not let it do that. You have to be having a push-pull problrm rather than a rotation problem.
YooperJD60
PostPosted: Fri Jan 11, 2019 4:16 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
I have no idea what the make/model is....I'm going to be working on it tomorrow..I'll take some pictures.
rustyfarmall
PostPosted: Fri Jan 11, 2019 5:34 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
I would drill a new 1/4" hole. A 5/16" shear bolt might not shear easily enough to protect the rest of the machine.
Michael Soldan
PostPosted: Fri Jan 11, 2019 7:15 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
Any PTO driven device will shear pins if the pins do not fit properly in the hole designated for the pin. Others have it right, drill both pieces of the PTO shaft to uniform diameter and put in a pin that fits.
Bob Bancroft
PostPosted: Fri Jan 11, 2019 7:16 am    Post subject: Re: PTO driven snowblower keeps shearing pins Reply to specific post Reply with quote
Is there a keyway in both the shaft and the yoke? Do you have a key in there? Usually there's a set screw to keep the key in place.
My sprayer has a 5/16" bolt which holds the yoke on the pump. There is also a set screw. Every once in a while the bolt disappears. It has done this since day one, when I bought it new.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
