Brakes on 1855. something aint right?
Goto page 1, 2  Next
bison
PostPosted: Thu Jan 10, 2019 11:47 am    Post subject: Brakes on 1855. something aint right? Reply to specific post Reply with quote
I am rebuilding an 1855.
I done the reared and transmission and am now in the process of putting the brakes together.
You can see in the pics that the brake piston had been riding against the bull pinion(with brake applied) but even with new brake discs there is only 1/16 clearance left between a fully retracted brake piston and the pinion with all brake parts in place
What am I missing here?
rrlund
PostPosted: Thu Jan 10, 2019 12:40 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
Was there supposed to be thin shims in there between the cover and housing or was that just some of the late ones with a mechanical actuator?
Dieseltech
PostPosted: Thu Jan 10, 2019 1:58 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
Are you sure the discs are the right thickness? If too thin that will cause the trouble you have.
IanC
PostPosted: Thu Jan 10, 2019 2:48 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
Have you backed out the adjusting screw for the parking brake actuator?
mkuhns
PostPosted: Thu Jan 10, 2019 4:36 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
Did someone machine the outer or separator plates too thin? That is about all it could be. I see the piece of fiber glued to the piston, so that isn't it. I would compare parts with the other side.
bison
PostPosted: Thu Jan 10, 2019 5:13 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
CVPost-mkuhns wrote:
(quoted from post at 17:36:01 01/10/19) Did someone machine the outer or separator plates too thin? That is about all it could be. I see the piece of fiber glued to the piston, so that isn't it. I would compare parts with the other side.
Both sides are identical in measurements.
Regardless of the internal brake parts is the fact that the brake pistons have a maximal travel of only 3/16' from all the way retracted till it bottoms out against the bull pinion. 1/16th of that travel is the necessary brake disc release clearance, which leaves only 1/8" to wear away on the discs before the piston hits the pinion,...which is not very much IMO.
Thicker brake discs would not fit as there is no room for it
New discs are just a wee bit over 1/2' thick.
gary66
PostPosted: Thu Jan 10, 2019 5:45 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
did brakes on my Truck and although the pistons were retracted as far as
they would go, they couldn't go all the way...new calipers were required.
I know this isn't the same, but something that old could be doing
something similar. If not I'd say wrong parts, these things can't be
complicated and loose is how I'd expect them to be.
Tractorcedric
PostPosted: Thu Jan 10, 2019 7:44 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
I have not done one of these for a long time! I suggest that you go to agcopartsbook online and look up the 1855. Page 113 items 28 and 34. Maybe someone else has miss matched these parts? Could change how many shims are under the housing.
bison
PostPosted: Thu Jan 10, 2019 8:17 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
CVPost-tractorcedric wrote:
(quoted from post at 20:44:23 01/10/19) I have not done one of these for a long time! I suggest that you go to agcopartsbook online and look up the 1855. Page 113 items 28 and 34. Maybe someone else has miss matched these parts? Could change how many shims are under the housing.
I have owned this tractor for 32 years and nothing has ever been done to the brakes.
parts #'s are identical to what is listed in my 1855 parts book and I got the new springs and discs from AGCO
Yes shim packs behind the brake/pinion housing will affect pinion to brake piston distance but that cannot be altered as the shim packs control differential/bull pinion end play.
Tractorcedric
PostPosted: Thu Jan 10, 2019 9:07 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
That's good that you know that no one else has been into it. Just curious does the parts book you have show two different inner bearings depending on serial number of your tractor. Maybe it got miss matched on the assembly line if it was close to the serial number break. From the picture on the net I am not sure were part 34 goes? Looks like some kind of spacer. I know what you mean about the shims under the housing as they are how you set the preload on the ring gear carrier. But different bearing sets may have a different overall thickness. A thicker bearing set would require more shims and give you more clearance. I have seen brake disc so worn that the piston came out of the bore enough to let the oring leak. But I don't remember if it had rubbed on the bull pinion. Question, If you place a straight edge over the brake housing and measure the distance to the bull pinion. Is it the same on both sides of the transmission? Just trying to help.
wilma
PostPosted: Fri Jan 11, 2019 4:40 am    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
Have you removed the piston from the housing? I had one that the stem for the parking brake part of the piston broke, although everything was still in tacked and not leaking, it created a situation like what you have by increasing the overall length/height of the piston
bison
PostPosted: Fri Jan 11, 2019 9:30 am    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
# 34 is an fiber insulator that goes between the brake disc and the adjuster plate.
The 0 rings in the piston housings have been replaced and everything looks fine in there.
Bull pinion face to end of housing distance are within a couple thou of each other.
Differential carrier and crown/pinion backlash have been reset to factory specs which required removal of 1 shim each side.
AFAIAC the only way to increase piston travel is to machine the face of the piston back a bit where it contacts the bull gear but there ain't enough meat Imo to do that safely without risking piston integrity.
I'm at a loss.
bison
PostPosted: Fri Jan 11, 2019 9:34 am    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
I'm at a loss.
Tractorcedric
PostPosted: Fri Jan 11, 2019 2:04 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
So are both pistons hitting the bull pinions? I must be looking at a different parts diagram than you. Part #10 is the friction disc bonded to the piston in the drawing I am looking at. I have tried to load the drawing I have and it won't load. It is at agcopartsbooks.com. I would sure like to help! 8zero1-55four-68eight6 Dennis
bison
PostPosted: Fri Jan 11, 2019 3:25 pm    Post subject: Re: Brakes on 1855. something aint right? Reply to specific post Reply with quote
(quoted from post at 15:04:30 01/11/19) So are both pistons hitting the bull pinions? I must be looking at a different parts diagram than you. Part #10 is the friction disc bonded to the piston in the drawing I am looking at. I have tried to load the drawing I have and it won't load. It is at agcopartsbooks.com. I would sure like to help! 8zero1-55four-68eight6 Dennis
Yep, both piston were hitting the pinions but new brake discs solved the problem for now.
The as you call it.. the friction discs.. are in my case not bonded to the pistons. as for the part # I relied on the # Tractorderic posted but it could be #10,..I did not verify.
All the part #'s on the pinion,brake housing, brake parts and cover are the same as listed in the 1855 parts book I have.
Goto page 1, 2  Next
Page 1 of 2
