What is part for and what implement is it for
Goto page 1, 2, 3  Next
deeretails
PostPosted: Thu Jan 10, 2019 6:07 pm    Post subject: What is part for and what implement is it for Reply to specific post Reply with quote
This is part is in the inventory I have. The images show it pretty well, couldn't find the number in the master catalogue. There is a bronze bushing with a 3/4" ID, and a place or a grease fitting. Casting Number is 3184.
Thanks-
Mike(NEOhio)
PostPosted: Thu Jan 10, 2019 7:28 pm    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Does the new JD online parts have a "where used" search? I remember the old one did.
Tx Jim
PostPosted: Fri Jan 11, 2019 3:26 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Yes the "New JD parts catalog" has a parts number search option. To my knowledge casting numbers weren't shown in old or new version of parts catalog part search unless casting number & parts number were the same which is rare.
I know on the old JD parts system "parts catalog in PDF form" the part numbers didn't show up in "where used search"
deeretails
PostPosted: Fri Jan 11, 2019 3:38 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Tried JD Parts on-line and it's no help.
Mike M
PostPosted: Fri Jan 11, 2019 4:48 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Are we sure it is even a JD part ? any sign of a JD logo cast in it ?
M-MAN
PostPosted: Fri Jan 11, 2019 6:45 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Doesn't look like it to me. Should be a prefix letter or logo.
Bob
PostPosted: Fri Jan 11, 2019 7:11 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
"Deeretails" posted a photo of another part a few days ago, and I thought it might not be a DEERE part because of no casting mark and an unusual part number, but I was WRONG, and this may well be a DEERE part, as well.
My though was it's a pivot point for a linkage, such as the clutch and brake linkage under the operator's platform of a combine, or other machine.
Looked at a few older combine parts catalogs with no luck, so far.
I would think it would be in the MPI of the appropriate era???
Other previously unknown DEERE part
Pete in MD
PostPosted: Fri Jan 11, 2019 11:30 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Jim,
I don't know if you're referring to hard copy parts catalogs. Casting numbers do show in them. An example is
the rockshaft housing for a Model B, one of several is p/n AB3640R. The description reads: Housing, B2612R,
with Bushing and Oil Seal. B2612R is the casting number on the housing.
deeretails
PostPosted: Sat Jan 12, 2019 3:37 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Folks, I'm sure this is a Deere part. I'm still digging into it as well, I think it may be a spreader part.
Tx Jim
PostPosted: Sat Jan 12, 2019 4:10 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
CVPost-Pete in MD wrote:
(quoted from post at 14:30:37 01/11/19) Jim,
Pete
I was referring to the "where used search" on JD parts site not the actual parts catalogs. I still remember the lecture I recieved from JD dealer "to be sure to read part descriptions & footnotes before selecting part #s" when I was 1st employed in parts dept at JD dealership back in the 60's.
Tx Jim
PostPosted: Sat Jan 12, 2019 4:36 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Pete
Same "no results found" when inserting casting # on new JD parts site also.
Jim
Pete in MD
PostPosted: Sat Jan 12, 2019 7:12 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Jim,
I understand what you're saying.
New question: B2612R shows up in the Master Index, PC-100, as used on Model Bs with two references to page
and key numbers. The page numbers are much higher than the number of pages in the B catalog, PC-330.
What catalog is it referring to?
Pete
Tx Jim
PostPosted: Sat Jan 12, 2019 9:14 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
What page #s are you referring to? I see it's listed on pages 78 key 34 & 102 key 20
Tx Jim
PostPosted: Sat Jan 12, 2019 9:18 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
OOPS I forgot to upload the page.
Pete in MD
PostPosted: Sat Jan 12, 2019 9:39 am    Post subject: Re: What is part for and what implement is it for Reply to specific post Reply with quote
Jim,
My Numerical Index PC-100 (6-50) shows B2612R on page 257, key 33 and page 327, key 17.
Page 1 of 3
