Resister needed?
T L
PostPosted: Fri Jan 11, 2019 3:34 pm    Post subject: Resister needed? Reply to specific post Reply with quote
I am changing a 8n to 12 volts. I have purchased a 12 volt coil. Do I need to add a resister from the switch to the coil?
Bruce (VA)
PostPosted: Fri Jan 11, 2019 3:57 pm    Post subject: Re: Resister needed? Reply to specific post Reply with quote
front or side distributor?
75 Tips
T L
PostPosted: Fri Jan 11, 2019 4:15 pm    Post subject: Re: Resister needed? Reply to specific post Reply with quote
Front distributer
Bruce (VA)
PostPosted: Fri Jan 11, 2019 4:22 pm    Post subject: Re: Resister needed? Reply to specific post Reply with quote
Yes, you need the oem ballast resistor and no others.
Is the oem ballast resistor installed on your tractor?
See tip # 31
75 Tips
T L
PostPosted: Sat Jan 12, 2019 12:41 am    Post subject: Re: Resister needed? Reply to specific post Reply with quote
Yes the original resister is there. I was affraid to use it because I thought it would burn out being a 6 volt resister. Thanks for the advice. When it warms up a little I will try to finish the conversion.
Farmer Dan
PostPosted: Sat Jan 12, 2019 4:09 am    Post subject: Re: Resister needed? Reply to specific post Reply with quote
CVPost-T L wrote:
(quoted from post at 16:34:36 01/11/19) I am changing a 8n to 12 volts. I have purchased a 12 volt coil. Do I need to add a resister from the switch to the coil?
You only need the original resistor no extra ones. Here is a diagram JMOR made hope it helps.
Bruce (VA)
PostPosted: Sat Jan 12, 2019 4:58 am    Post subject: Re: Resister needed? Reply to specific post Reply with quote
" I thought it would burn out being a 6 volt resister."
Nope. 6v or 12v doesn't matter to this resistor. It's there to reduce current to the coil when the tractor is running.
75 Tips
