Author |
Message |
LMack Long Time User
Posted: Fri Jan 11, 2019 5:44 pm Post subject: C 20 Tail Wheel |
Where can I find the tail wheel (thin metal only) for a C 20 plow? My bearing is fine but I need the wheel. I have though about taking a small disk and cutting out the center and welding it to the old disk that has the outside edge rusted away. |
Back to top |
fastfarmall Tractor Expert
Posted: Fri Jan 11, 2019 5:58 pm Post subject: Re: C 20 Tail Wheel |
Yeah crafting one your self, or hiring some one to make one is a good option, at least your bearing and hub is good !! |
Back to top |
Rex Simpkins Long Time User
Posted: Sat Jan 12, 2019 1:39 am Post subject: Re: C 20 Tail Wheel |
You can look through newer IH plows and find a tail wheel that will work I used one off of a much newer IH plow the bolt pattern was the same only difference was the new one is not curved on the edge but flat, and its a lot thicker metal. |
Back to top |
WESnIL Regular
Posted: Sat Jan 12, 2019 11:53 am Post subject: Re: C 20 Tail Wheel |
That should be IH part number PO 23 448. With the three sides and a curved edge that would be tough to make and look correct. Try Mike at Duffield Equipment (717)552-1951, Andrew Ginter (574)292-0248, Steve Smith (419)618-0017, or Andrew Tucker (812)878-7226 for possible replacement wheels. |
Back to top |
OldFarmall450 Long Time User
Joined: 21 Apr 2016 Posts: 615 Location: Wichita Falls, Texas by Gawd!!
Posted: Sat Jan 12, 2019 9:46 pm Post subject: Re: C 20 Tail Wheel |
CVPost-WESnIL wrote: | (quoted from post at 12:53:31 01/12/19) That should be IH part number PO 23 448. With the three sides and a curved edge that would be tough to make and look correct. Try Mike at Duffield Equipment (717)552-1951, Andrew Ginter (574)292-0248, Steve Smith (419)618-0017, or Andrew Tucker (812)878-7226 for possible replacement wheels. |
Back to top |
