Fitttings on power steering, Ford 5000
ed1
PostPosted: Sat Jan 12, 2019 1:09 am    Post subject: Fitttings on power steering, Ford 5000 Reply to specific post Reply with quote
Ok, I got my new power steering pump. I have to remove the fittings from the old pump and was wondering what would be the best sealant to use? Also, I assume that 134D would work in the new pump.Any input would be appreciated.
ed1
RickB
PostPosted: Sat Jan 12, 2019 2:30 am    Post subject: Re: Fitttings on power steering, Ford 5000 Reply to specific post Reply with quote
134 is the recommended fluid. ORB and JIC style fittings do not use any type of sealant. Tapered pipe thread connections do need to be sealed.
Sean in PA
PostPosted: Sat Jan 12, 2019 5:45 am    Post subject: Re: Fitttings on power steering, Ford 5000 Reply to specific post Reply with quote
My '73 4000 power steering pump has flare fittings on the lines at the pump. No sealant needed. A 5000 should be the same, at least with the later style pump with the reservoir integrated into the pump housing. I'm not sure what type of fittings the earlier style pumps with the separate reservoir used, but I would assume that they would be the same at the pump end. The parts drawing shows o-rings at the ends of the lines at the cylinder but it doesn't show any details for the ends at the pump.
ed1
PostPosted: Sat Jan 12, 2019 5:48 am    Post subject: Re: Fitttings on power steering, Ford 5000 Reply to specific post Reply with quote
Ok guys I thought they might be tapered.
Thanks for your help.
ed1
