Gooseneck hitch collapsed
Rodeo man
PostPosted: Fri Jan 18, 2019 9:06 am    Post subject: Gooseneck hitch collapsed Reply to specific post Reply with quote
I was driving down the road yesterday, with 14K pounds on my cow trailer. Hit a little bump, and boom. The trailer slid down the sleeve on the coupler. Luckily, I have a flat bed, or there would have been serious damage. Just readjust the height, and tighten those set bolts as tight as I can? Am I missing something?
showcrop
PostPosted: Fri Jan 18, 2019 10:10 am    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
I would get a good look at the inside of the tube. I adjusted mine a little when I got it and it has been ten years. If it has too much rust scale inside, it could interfere with the friction which is all that holds it.
rrlund
PostPosted: Fri Jan 18, 2019 11:00 am    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
You're lucky that's all that happened. There's a custom hauler here who has a couple of trucks and aluminum trailers. His brother was driving one for him one day and got stuck in a farm yard. They hooked on to him with a FWA tractor and took off. The truck moved,but the trailer didn't. It folded the front of the trailer right up and the hitch was sticking straight out toward the truck.
Destroked 450
PostPosted: Fri Jan 18, 2019 4:50 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
Set it to the height you want and drill a 1/2" or bigger hole thru the tongue and put a long bolt or pin thru the hole.
My 20K tandem dually trailer came with the two clamp bolts and a 5/8" pin going thru the side of the neck.
The inner tube as holes every couple of inches for height adjustments, the clamp bolts keeps the hitch tight.
Rodeo man
PostPosted: Fri Jan 18, 2019 5:37 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
Destroked 450 wrote:
(quoted from post at 01:50:40 01/19/19)
A grade 8 bolt would probably be strong enough wouldn’t it?
DC Snider
PostPosted: Fri Jan 18, 2019 6:17 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
I would've thought it would've had a pin in it already. A 5/8 grade 8 bolt would work just fine. As Destroked said, the set screws should just keep the hitch from working.
Determined
PostPosted: Sat Jan 19, 2019 12:20 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
Could you cut a piece of pipe to act as a travel stop and slide it in before you slide the sleeve in?
Traditional Farmer
PostPosted: Sat Jan 19, 2019 1:11 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
Best Idea.
Rodeo man
PostPosted: Sat Jan 19, 2019 3:01 pm    Post subject: Re: Gooseneck hitch collapsed Reply to specific post Reply with quote
Determined wrote:
(quoted from post at 21:20:13 01/19/19) Could you cut a piece of pipe to act as a travel stop and slide it in before you slide the sleeve in?
That is an excellent idea.
