Engine Swap
raymondy
PostPosted: Fri Jan 18, 2019 1:35 pm    Post subject: Engine Swap Reply to specific post Reply with quote
This has probably been asked but after searching I couldn?t find anything on it. Will a 5020 engine fit in to a 4020 housing? Frame rails different? Engine length different? Has anyone done this before. Currently have a 4020 with a gas and wanted to bump the HP/torque on it. I attached a picture of the 5020 engine tag.
Thanks,
-Raymond
D-
PostPosted: Fri Jan 18, 2019 1:55 pm    Post subject: Re: Engine Swap Reply to specific post Reply with quote
Won't fit but a 466 will.
tlock0331
PostPosted: Fri Jan 18, 2019 9:16 pm    Post subject: Re: Engine Swap Reply to specific post Reply with quote
no, it wont, not without a LOT of money and machining. the 5020 series engine is different than the 4020 series.
but my bigger question is, that block is yellow, what did that engine come out of? 5020's didnt have industrial yellow paint. surely it wasnt a 700. Thats a much more important question....
buickanddeere
PostPosted: Sat Jan 19, 2019 6:43 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
. A Siamese port 466 with a turbo will make more power than any 531 .
raymondy
PostPosted: Sat Jan 19, 2019 7:02 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
Sorry for not knowing but, what would I grab one of these out of? A
combine transplant?
buickanddeere
PostPosted: Sat Jan 19, 2019 9:44 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
If TimS chimes in. There isn't anything about swapping motors into 4020's that he doesn't know about .
I haven't tried the new online parts books at the JD web site. The old site used to cross reference every machine that a known part number was used in.
What are the plans for this 4020 and is it an early or late model ?
larryanderson
PostPosted: Sun Jan 20, 2019 9:32 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
Salvage yard is best source. Many have been done and there are ways to save time and money.Tim S. would be an expert source.I have been told a 105 404 combine engine is a match but have seen some with 466s that were nicely done.
Tx Jim
PostPosted: Sun Jan 20, 2019 10:48 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
buickanddeere wrote:
(quoted from post at 09:43:28 01/19/19) . A Siamese port 466 with a turbo will make more power than any 531 .
b&d
May I ask which JD 466 cid engines have Siamese port cyl. heads? Thanks,Jim
buickanddeere
PostPosted: Sun Jan 20, 2019 3:58 pm    Post subject: Re: Engine Swap Reply to specific post Reply with quote
Tx Jim wrote:
(quoted from post at 14:48:40 01/20/19)
b&d
55 series iirc . I should look at that parts book instead of my memory.
Tx Jim
PostPosted: Mon Jan 21, 2019 3:20 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
I guess that's the reason 55 series rowcrop tractor engines are identified a 6076 engines instead of 466 cid although they are 466 cid
tim s
PostPosted: Mon Jan 21, 2019 6:30 am    Post subject: Re: Engine Swap Reply to specific post Reply with quote
"Siamese port cyl. head" would be a way of describing a latter 466 head,4455's and up, where the intake ports share the same opening instead of being divided in the middle.They also have a larger opening in the intake manifold for better air flow.
