Kingdom gets a new steed
Goto page 1, 2  Next
jon f mn
PostPosted: Sat Jan 19, 2019 7:26 am    Post subject: Kingdom gets a new steed Reply to specific post Reply with quote
This popped up on FB for sale and I
made the mistake of saying it was too
bad I was broke because it was close
and I wanted one. Lol. Onve the guy saw
that he latched on to me and wouldn't
let go til I owned it. My boss even let
me use the company truck to get it
home.
Pretty straight and tires are good but
cracking some.
The loader has been used hard and needs some attention. This in particular caught my eye. Lol
It runs good and everything works as it should except the com which needs some attention. I'm hoping it's just a valve issue, I know at least part of the problem is there.
It also came with a new seat and some paint which I haven't looked at yet. And these manuals came with as well.
He gave me this belr buckle too, I like it.
So looks like another project do take care of before spring. But it will fit right in with the rest of the crew.
View user's profile AIM Address
Case Nutty 1660
PostPosted: Sat Jan 19, 2019 7:36 am    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Looks Good Jon and Congrats you will have her working like it should soon enough I am sure,
cnt
olgentdc
PostPosted: Sat Jan 19, 2019 8:13 am    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
You Did REAL Good Jon,,. somethings just got to be done . i did not take time to note ..is it a gasser or diesel
jon f mn
PostPosted: Sat Jan 19, 2019 8:20 am    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Diesel
BarryfromIA
PostPosted: Sat Jan 19, 2019 9:38 am    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
830 Case-o-matic diesel is my guess. You need a about 300 to 500 acres to farm now.
KENIND
PostPosted: Sat Jan 19, 2019 9:46 am    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
I think ya did all right. I've seen a whole lot worse ones out there................Kenny
Ande
PostPosted: Sat Jan 19, 2019 1:28 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Always good to have 2 loaders, and you will have lots of work for it. Going to let you in on a secret thou, as now something is missing,,,, (shhhh,,, 930)
VAC400
PostPosted: Sat Jan 19, 2019 4:29 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Jon, what a great find. The tractor will have a good home an well taken care of. I found the 770 on craigslist an it followed me home. Jerry from Ohio
Ande
PostPosted: Sat Jan 19, 2019 4:55 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Looks like the same Case loader
jon f mn
PostPosted: Sat Jan 19, 2019 5:24 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
It does, could use that bucket
kevinthefixer
PostPosted: Sat Jan 19, 2019 6:06 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Not the same tilt cylinder setup as mine, though, and AFAIK mine is all stock. Had to put new steel in the crossbar, though, it was only 1/8 thick and tore.
It looks like someone used a different cylinder on yours and had to extend those ears to make it work, maybe it's a little longer? I scanned the loader manual (parts) and made it a .pdf if you need it.
291BLoaderPartsManual
Ande
PostPosted: Sat Jan 19, 2019 6:19 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
You can see my bucket is peeled back like a sardine can.
Here is the fix on my loader
jon f mn
PostPosted: Sat Jan 19, 2019 6:21 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
Thanks! The cylinder is definitely not original. I'm not sure what I'll do with that yet.
jon f mn
PostPosted: Sat Jan 19, 2019 6:47 pm    Post subject: Re: Kingdom gets a new steed Reply to specific post Reply with quote
I could fix that. Lol
kevinthefixer
First thing I'd do, Jon, is use it until it breaks. If it doesn't break, don't fix it. That may look like a set of monkey bars, but as long as the monkey isn't King Kong you might just be alright. If you do have to fix it I recommend replacing that center tube, as I said it's only 1/8" wall. I made the mistake of cutting mine out with a torch, the thing to do is cut it apart with abrasive wheels so you have a nice clean line to weld it back together with. IIRC those side plates are 3/8", when I welded the 1/4" thick square tube to it I needed about 190 amps to get it to sink in with 6013 rod. Then I chased it with 7018, it hasn't shown any cracks yet and I've been abusing it for a year now.
Goto page 1, 2  Next
Page 1 of 2
