504 Head Gasket Problems and Misc.
amsinator
PostPosted: Mon Jan 21, 2019 6:54 am    Post subject: 504 Head Gasket Problems and Misc. Reply to specific post Reply with quote
This message is a Question subject matter of an archived post. I am trying to reactivate this thread for IH 504 utility w/ D188 Diesel head gasket, and oil passage/water seal inserts, showing "failing inserts from coolant passages" Posted by 1370rod on January 21, 2015.
Having recently acquired a 504 utility w/ D188 due to exhaust "spewing out green coolant" after trying to start by past owner when tractor sat through the "Record Term (2 weeks) of below freezing temps of 17F-25 F degrees F" last January 2018. Since that time PO also found dipstick tube filled to top with what looks like water, which I assume is coolant.
What I am in process of doing is tearing down to determine failure.
During durations of freezing weather it is understood the importance of anti-freeze protective levels. I can only assume it had antifreeze in tractor by spewing out distinguishable green coolant, but freeze protection is unknown/mute point for now.
Does the D188 have a reputation of pushing out water jacket (freeze plugs) in certain areas, such as under valve cover gasket?
I am thinking head gasket let go, since coolant was blown out exhaust upon last cranking attempt and filling crankcase with coolant/water by visual inspection. Trying to work on it Today, but presently 25 degree F, lots of layers to be able to work outside.
Adirondack case guy
PostPosted: Mon Jan 21, 2019 7:00 am    Post subject: Re: 504 Head Gasket Problems and Misc. Reply to specific post Reply with quote
You need to drop down to the IH-Farmall forum. When some one here mentions a 504 we are talking about the 504cu.in. engine used in big Case tractors not a little red tractor.
Loren
amsinator
PostPosted: Mon Jan 21, 2019 7:48 am    Post subject: Re: 504 Head Gasket Problems and Misc. Reply to specific post Reply with quote
I have posted this in IH forum and reported to moderator.
Thanks for the quick response.
Al
1370rod
PostPosted: Mon Jan 21, 2019 4:22 pm    Post subject: Re: 504 Head Gasket Problems and Misc. Reply to specific post Reply with quote
I have responded to Case 504 engine questions but never recall ever mentioning a 504 IH, Rod.
