farmall cub throwout bearing
fabohren
PostPosted: Mon Jan 21, 2019 11:11 am    Post subject: farmall cub throwout bearing Reply to specific post Reply with quote
Does it have to be replaced with a graphite 1 or do they make a metal 1 with an actual bearing. Pros and cons of either. Replaced with graphite and did not last long. Possible it was not adjusted correctly from the git go, any advice would be appreciated. Thanks Fred
fabohren
PostPosted: Mon Jan 21, 2019 1:55 pm    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
We will go with the graphite and be more careful with the adjustment. The original lasted over 50 years, so it is more than likely we had the adjustment wrong. Thanks for taking time to get back to me. Fred
47fivewindow
PostPosted: Mon Jan 21, 2019 6:37 pm    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
The old graphite ones were prelubed, but the new ones need to be soaked in oil overnight. They need to be greased with cheap grease that will seperate so the oil will wick to the face.
View user's profile AIM Address
fabohren
PostPosted: Tue Jan 22, 2019 2:58 pm    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
We will defiantly soak it in oil, I assume it should be lite weight. 5/20 or real lite like 3 in 1, and then reg. grease or white lithium? Thanks Fred
DR. EVIL
PostPosted: Wed Jan 23, 2019 3:32 am    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
Coworker 25 years ago had a Cub Farmall, replaced throw-out bearing with the graphite bearing, only lasted minutes of run time. He did some research and discovered CIH had changed suppliers of the bearing and the graphite material had changed. Then he discovered a machine shop in his little town between Milwaukee and Madison, Wis was the old supplier and was making them again.
Very possible one of those old wrong material bearings was in inventory at a dealer or parts warehouse.
47fivewindow
PostPosted: Wed Jan 23, 2019 4:41 am    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
Motor oil is what is normally recommended for presoak. I would probably warm it up this time of year.Tomato can on the wood stove? The grease is cheap chassis lube, not extreme pressure. The warmth of the friction melts the cheap grease and the oil wicks into the graphite. The wax carrier gets pushed out with the next lube. So I've been told.
fabohren
PostPosted: Wed Jan 23, 2019 2:56 pm    Post subject: Re: farmall cub throwout bearing Reply to specific post Reply with quote
Thanks again to all of you. A lot of things in life seem to go as DR Evil states, something is good and someone tries to make it better or cheaper and it does not work out. Fred
