Author |
Message |
Kennyspielman New User
Posted: Tue Feb 05, 2019 9:47 pm Post subject: sediment bulb |
How can I tell if my thumbscrew to the sediment bulb is open or closed? It also appears to be leaking at the nut before the sediment bulb. Is there a gasket inside there that may require replacing? |
Back to top |
caterpillar guy Tractor Guru
Posted: Wed Feb 06, 2019 3:20 am Post subject: Re: sediment bulb |
If you are talking about around the nut holding the shutoff shaft you turn there is packing inside that nut. You will have to adjust it to not leak yet be able to turn the shutoff. |
Back to top |
FBH44 Tractor Guru
Posted: Wed Feb 06, 2019 6:46 am Post subject: Re: sediment bulb |
I am replacing the bulb / sediment glass bowl on my Farmall H. Got a new one from this site, which I will install shortly. Both the new one and the old one, all have right-hand threads. In other words, looking at the knob from the driver's seat, turn everything clock-wise to shut it off, to tighten it up. |
Back to top |
Ellis Kinney Tractor Expert
Posted: Wed Feb 06, 2019 6:55 am Post subject: Re: sediment bulb |
Gently snug the nut down a little until there is a slight resistance when you tighten the thumb screw. The gasket at the top of the sediment bowl could also be leaking. The gasket is probably sold on this site for a couple of dollars. Ellis |
Back to top |
Cmore Regular
Posted: Wed Feb 06, 2019 7:41 am Post subject: Re: sediment bulb |
Try wrapping Plumbers Tape around the shut off thing. Or dental floss also works |
Back to top |
OldFarmall450 Long Time User
Joined: 21 Apr 2016 Posts: 665 Location: Wichita Falls, Texas by Gawd!!
Posted: Wed Feb 06, 2019 1:05 pm Post subject: Re: sediment bulb |
All good info...my dad used the string from feed sacks to pack the valve..just unscrew the cap, turning counter clockwise from rear of tractor, wind up some floss, thread, thread tape, etc., then tighten it up. The gasket where the bulb mounts to the valve is notorious for leaking...be sure and check there.
Also, I bought the inside tank filter that attaches to the sediment valve from here...it forces your tractor to use fuel about 2 inches above bottom...really cuts down on crud in the carb/fuel line. Best money I've spent on my tractor. |
Back to top |
