My first 8N 1951 SN# *8N356218*
Goto page Previous  1, 2, 3 ... 9, 10, 11
Den N Ms
PostPosted: Sat May 04, 2019 8:05 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Lance,You might think about setting the front wheels/axle in a notch or two if Wynn is goimg to use it inside the barn for more stall clearence.Also raise the 3 point hitch above the trailer frane so it would not catch the frame if the PTO didn't acidently get turned on and the control was in the raised position.Looks GREAT good job.
Lance-W
PostPosted: Sat May 04, 2019 12:13 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Den N Ms wrote:
(quoted from post at 09:05:44 05/04/19) Lance,You might think about setting the front wheels/axle in a notch or two if Wynn is going to use it inside the barn for more stall clearance.Also raise the 3 point hitch above the trailer frane so it would not catch the frame if the PTO didn't acidently get turned on and the control was in the raised position.Looks GREAT good job.
Yup we had a conversation this morning about the three point and it fouling on the trailer tongue. I figured we could just take the stabilizer bars off and the draw bar out but your idea of simply moving it above the tongue would work just as well then when you want to use the 3 bar you don't have to find all the stuff that you took off.
Yup, I think Hobo mentioned the width of the front end before. I think at this point I'm gonna leave it where it is and see if it causes problems. Wide like this it makes it a bit more stable and the "barn aisles" are actually outside adjacent to the stalls where there is a two rail fence and a planter creating "the aisle" so there's a bit more room than if you were driving it down the middle of a barn.
Hobo,NC
PostPosted: Sat May 04, 2019 4:11 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Before I made a 3 point trailer hitch I put a trailer ball in the 11 hole draw bar and made a Ho-made draw bar lock to keep the drawbar from turing. I never use stays to keep the 3 point from going up never had a issue BUT was aware of the possibility...
https://forums.yesterdaystractors.com/viewtopic.php?t=1123642&highlight=slide
Go EZ on me YTDOT :lol: YMMV
Lance-W
PostPosted: Sat May 04, 2019 4:51 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 17:11:49 05/04/19)
Very nice and VERY simple :D
Hobo,NC
PostPosted: Sat May 04, 2019 5:25 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
No lazy and cheap... But not so lazy and cheap to pick up scrap others throw away...
Lance-W
PostPosted: Sat May 04, 2019 5:57 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 18:25:00 05/04/19)
Lazy, cheap, elegant and simple is a great combination :D
wpmiller9887
PostPosted: Sun May 05, 2019 5:56 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Spray paint it red!
Lance-W
PostPosted: Sun May 05, 2019 2:41 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Thank You Hobo !!!
Lance-W
PostPosted: Sun May 05, 2019 2:42 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
The wood sides and floor are drying as I type :)
Hobo,NC
PostPosted: Sun May 05, 2019 2:50 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
LW don't fudge around dose he... That's nice you must have a machine shop in your garage...
Lance-W
PostPosted: Mon May 06, 2019 5:03 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
lastcowboy32 wrote:
(quoted from post at 05:23:51 05/04/19) That is a fantastic.
I like the oil pressure switch idea. I'm rigging my 2N with lights (definitely not original...) and the oil pressure-triggered buzzer sounds like a great idea; as long as I'm messing with the wiring.
I really appreciate all of the details.
I hope that your wife has many enjoyable years using this tractor!
So the story on the oil pressure switch buzzer. It's really very simple.
I used one of these from epay for the buzzer
And one of these from Rock Auto. This you could probably buy anywhere it just needs to have a set of normally closed (un-pressurized) contacts
Then you simply wire it up from ground on one side of the buzzer through the pressure switch to positive. The buzzer is polarity sensitive ( :roll: I couldn't for the life of me figure out why that simple circuit didn't work till the the light in my pea brain went on and I thought about polarity) and the fittings are 1/4" tube with a 1/8" pipe for the sensor. Those I scrounged so I don't have a source to point you to but I'm sure McMaster-Carr would have what you need.
Lance-W
PostPosted: Sun May 12, 2019 3:47 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Whelp! It went to work today. Feels like a kid going to their first day of school.............
Page 11 of 11
