1927 Gotfredson Truck - Clark differential
Goto page 1, 2  Next
tvscum
PostPosted: Tue Feb 19, 2019 9:02 am    Post subject: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
I am trying to replace the washer and felt seal in this 1927 Clark differential to fix an oil leak. I got the drive shaft flange off, which is held on with a bolt. But can't get the washer/felt seal out. Notice the castle-type adjustment rings on the outside. Do those have to come off too? I am worried if I take those off the pinion gear adjustment will get screwed up.
tvscum
PostPosted: Tue Feb 19, 2019 9:08 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
https://photos.app.goo.gl/feivVAmfaqyvJMkQ7
https://photos.app.goo.gl/m4CErPnXP3iQrScF6
https://photos.app.goo.gl/UmNHQYhR5R8oxGgDA
https://photos.app.goo.gl/QkwHJrK1FAJ8nyvP6
tvscum
PostPosted: Tue Feb 19, 2019 9:10 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
Those links above may not work... try these.
showcrop
PostPosted: Tue Feb 19, 2019 9:40 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
What is that silver stuff? I would be scraping some of that away to get an idea of hothouse rings may engage the inner ring.
tvscum
PostPosted: Tue Feb 19, 2019 10:05 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
showcrop wrote:
(quoted from post at 10:40:07 02/19/19)
If you are talking about he silver metal ring, that is the washer that I am assuming holds the felt seal in.
If you are talking about the granular stuff, it may be sand residue from when the differential was sandblasted.
At any rate, I am trying to get that washer out to install a new felt seal, or perhaps a more modern seal.
showcrop
PostPosted: Tue Feb 19, 2019 12:06 pm    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
tvscum wrote:
(quoted from post at 11:05:03 02/19/19)
I see now that what looked like silver is actually black. It looks like a very thick coating of paint
jm.
PostPosted: Tue Feb 19, 2019 12:52 pm    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
My best guess is you do not want to take the front off. Tat bolt loosens up and one turns that collar with the notches to set the pinion to the ring gear, (just what it looks like) . Looking at the yoke you removed looks like the seal rides on it but then the key way would leak so I am thinking you are ring in that you need to go deeper but how. One might take a small drill bit and drill the washer and try a screw on a slide hammer but that is just a guess. I am betting you can come up with a late model seal that will work if you can get back to where it needs to be installed.
Ozlander
PostPosted: Tue Feb 19, 2019 1:04 pm    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
I would think that if you have to take that collar off, just count the turns off, then same number of turns on. Maybe a wee bit more for wear.
tvscum
PostPosted: Tue Feb 19, 2019 1:14 pm    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
Right, so it actually looks like there are two rings with castle notches on them. Perhaps the inside ring holds the washer and seal, and the outside ring adjusts the pinon gear? Otherwise, why have two rings?
jm.
PostPosted: Tue Feb 19, 2019 1:21 pm    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
Well looks like you may be right, so one would remove the lock tab then back maybe the inside nut out and get to your seal, that would make sense in that one could actually tighten the old seal. Back in those days seals were very primitive. What ever you do please post back photos and results. I am 75 years old and worked on a lot of old stuff but nothing exactly like that.
caterpillar guy
PostPosted: Wed Feb 20, 2019 6:17 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
From the rear axles I've worked on. I don't believe that those rings are plastic since most of things made during that time frame were made out of steel or are cast iron or a few cast steel parts. What are those bolts in the section behind that clamp looking deal. They might just, adjust the ring and pinion gear set. Especially if there are shims there. The nut holding the yoke/flange for the drive shaft would probably hold the pinion shaft tight in the front casting.
Bill(Wis)
PostPosted: Wed Feb 20, 2019 6:18 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
Try: 888-383-3301 or 360-793-3661. Arm yourself with as much info about the axle you're dealing with ahead of time. Serial #,
model#, etc. or pictures. Good luck.
tvscum
PostPosted: Wed Feb 20, 2019 8:17 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
CVPost-caterpillar guy wrote:
(quoted from post at 07:17:26 02/20/19) From the rear axles I've worked on. I don't believe that those rings are plastic since most of things made during that time frame were made out of steel or are cast iron or a few cast steel parts. What are those bolts in the section behind that clamp looking deal. They might just, adjust the ring and pinion gear set. Especially if there are shims there. The nut holding the yoke/flange for the drive shaft would probably hold the pinion shaft tight in the front casting.
Thank you for your help. The rings (B and C in the linked photo below) are definitely iron. I have not tried to move them yet. They are locked in place with the bolt (E). Good thought, the bolts and plate (D) could have shims underneath and might hold the pinon in. The levers left and right are brake linkage.
https://photos.app.goo.gl/t8bZX1uXZRDxn8gx9
tvscum
PostPosted: Wed Feb 20, 2019 8:23 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
CVPost-Bill(Wis) wrote:
(quoted from post at 07:18:03 02/20/19) Try: 888-383-3301 or 360-793-3661. Arm yourself with as much info about the axle you're dealing with ahead of time. Serial #,
I will give them a call. I believe the truck came with a Clark B307 but it could have been changed out over the decades. It appears to be similar to this rear end mentioned in an article from 1921:
https://photos.app.goo.gl/9ZVfo458cGgPu2PT8
Bob
PostPosted: Wed Feb 20, 2019 8:48 am    Post subject: Re: 1927 Gotfredson Truck - Clark differential Reply to specific post Reply with quote
tvscum wrote:
(quoted from post at 11:23:32 02/20/19)
Looks to me like the front/smaller notched adjustment sleeve "B" sets the bearing "preload" and the larger adjustment sleeve "C" sets "pinion depth".
Before you removed the yoke, was there any play in the bearings or could you feel a "pre-load"?
If you have to remove threaded sleeve "B" to access the seal, when putting it back you just need to get it back where the "feel" of the bearings is the same as it was, or slightly more "snug".
If you have ever "set up" axle bearings before, this will make more sense to you.
Goto page 1, 2  Next
Page 1 of 2
