3020 wishbone update
Goto page 1, 2  Next
SVcummins
PostPosted: Thu Feb 21, 2019 1:14 pm    Post subject: 3020 wishbone update Reply to specific post Reply with quote
If you remember I broke the front drawbar support
Around December I had a local guy weld so I
couldn?t go until the new one got here well the new
used one finally got here today . I?m half tempted to
keep running the welded one because it is strong
but I do worry about a two way plow and the power
harrow swinging around back there
Janicholson
PostPosted: Thu Feb 21, 2019 1:35 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
The reason the original broke is to be avoided. If it is working, and you can avoid the circumstances, run it. Jim
NY 986
PostPosted: Thu Feb 21, 2019 1:36 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Your luck might run out on that welded one so I would change it ASAP.
ADB-Ia
PostPosted: Thu Feb 21, 2019 2:11 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Six years ago I welded the main drive shaft on the bean head of my combine to get me through the night. I went and got the new shaft the next day. Four thousand acres later the new shaft is still in the corner of my shop.
tim s
PostPosted: Thu Feb 21, 2019 2:23 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
It's better have it and not need it...Than to need it and not have it....
Adirondack case guy
PostPosted: Thu Feb 21, 2019 3:24 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
You should be a script writer for a reality show featuring the life of SVcummins. The show could spend at least 20 minutes dramatizing the viewers with that problem.
Loren
NY 986
PostPosted: Thu Feb 21, 2019 3:37 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Not sure what that means but he would not be the first to have a weld job fail him at the most inopportune time and have a lot more damage than the first go round. I've heard of guys having welds fail on those wishbones so it does happen. He can do as he sees fit.
Traditional Farmer
PostPosted: Thu Feb 21, 2019 4:31 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
I'd put the new one on and keep the welded one for a spare
DoubleO7
PostPosted: Thu Feb 21, 2019 4:32 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
You mentioned in another thread about maybe reinforcing the repaired one or even the new one.
I would not do that as the next part up the line to break maybe
unrepairable, unobtainable or way more expensive.
SVcummins
PostPosted: Thu Feb 21, 2019 5:53 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
I think I will probably run the welded one until spring then swap it out so I don?t have to worry about it breaking during the summer when I need it to be running without any delays .
SVcummins
PostPosted: Thu Feb 21, 2019 6:08 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
DoubleO7 As strong as this welded one is I don?t
think it needs anymore strength added
SVcummins
PostPosted: Thu Feb 21, 2019 6:09 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Traditional That?s what I will do when spring hits and I don?t have to lay in a snow drift to swap them out
SVcummins
PostPosted: Thu Feb 21, 2019 6:12 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Tim That?s what I thought and I found a good used one for 175$ all states ag wants 750$ used
SVcummins
PostPosted: Thu Feb 21, 2019 6:14 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
ADB If this wasn?t such a pain to change right in the middle of summer I?d leave it on there . This welded one has proven its strength though
SVcummins
PostPosted: Thu Feb 21, 2019 6:16 pm    Post subject: Re: 3020 wishbone update Reply to specific post Reply with quote
Janicholson I was using an implement with to wide off pin spacing on the 3 point arms . I knew the tractor was trying to tell me something when it was so hard to get the scraper hooked on and I kinda thought about it a little but didn?t worry about it
Goto page 1, 2  Next
Page 1 of 2
