2394 no reverse
slatevalley
PostPosted: Mon May 21, 2007 9:01 am    Post subject: 2394 no reverse Reply to specific post Reply with quote
The powershift switch went bad ,also the circutt board went out . After replacing them , i only have reverse when then machine is cold.When you put it in reverse I starts to roll then quits.
dwag
PostPosted: Mon May 21, 2007 9:53 am    Post subject: Re: 2394 no reverse Reply to specific post Reply with quote
With lever in Rev, C2&C4 solenoids should be energized, To check, put a flat washer on each solenoid, magnetic pull will hold washers on. Sounds like C4 solenoid is weak or bad, could check amp draw to C4, also trans pressure at C4.
