830 cracked heads
Fred eagerton jr.
PostPosted: Mon May 21, 2007 2:38 pm    Post subject: 830 cracked heads Reply to specific post Reply with quote
Ihave a 830 that I got from my uncle, it would not run, sounded like a burnt valve, pulled heads off sunday afternoon and both heads are cracked and show signs of overheating, Anyone out there have 2 heads i could get or know where to look. CAST # ON HEADS ARE A21003. Thanks, Fred
Jim B.
PostPosted: Mon May 21, 2007 6:38 pm    Post subject: Re: 830 cracked heads Reply to specific post Reply with quote
Do you need... Gas, Diesel or LP heads?
Fred Eagerton Jr.
PostPosted: Tue May 22, 2007 3:41 am    Post subject: Re: 830 cracked heads Reply to specific post Reply with quote
It is a 301D diesel engine
Jheitkemper
PostPosted: Wed May 23, 2007 10:20 am    Post subject: Re: 830 cracked heads Reply to specific post Reply with quote
thwere is a guy in E town Ky , that welded and reworked mine for an 800 .. Depending on how bad they are ,, You will pay BIG Bucks either way ..Best wishes , Jim
Fred Eagerton Jr.
PostPosted: Wed May 23, 2007 6:38 pm    Post subject: Re: 830 cracked heads Reply to specific post Reply with quote
A man offered 2 heads off of a 930 today, the bolt holes seem to match up, but the heads are a little bit shorter. think i could use the push rods out of the 930 and if the water jackets match up, would it work, Only out of some time and a little $ enstead out of 900$ for 2 remaned heads.
Eric John
PostPosted: Wed Jun 06, 2007 7:55 pm    Post subject: Re: 830 cracked heads Reply to specific post Reply with quote
The 930 case has a smaller bore. I do not believe that the heads will work.
