Author |
Message |
Fred eagerton jr. Guest
Posted: Mon May 21, 2007 2:38 pm Post subject: 830 cracked heads |
Ihave a 830 that I got from my uncle, it would not run, sounded like a burnt valve, pulled heads off sunday afternoon and both heads are cracked and show signs of overheating, Anyone out there have 2 heads i could get or know where to look. CAST # ON HEADS ARE A21003. Thanks, Fred |
Back to top |
Jim B. Guest
Posted: Mon May 21, 2007 6:38 pm Post subject: Re: 830 cracked heads |
Do you need... Gas, Diesel or LP heads? |
Back to top |
Fred Eagerton Jr. Guest
Posted: Tue May 22, 2007 3:41 am Post subject: Re: 830 cracked heads |
It is a 301D diesel engine |
Back to top |
Jheitkemper Guest
Posted: Wed May 23, 2007 10:20 am Post subject: Re: 830 cracked heads |
thwere is a guy in E town Ky , that welded and reworked mine for an 800 .. Depending on how bad they are ,, You will pay BIG Bucks either way ..Best wishes , Jim |
Back to top |
Posted: Wed May 23, 2007 6:38 pm Post subject: Re: 830 cracked heads |
A man offered 2 heads off of a 930 today, the bolt holes seem to match up, but the heads are a little bit shorter. think i could use the push rods out of the 930 and if the water jackets match up, would it work, Only out of some time and a little $ enstead out of 900$ for 2 remaned heads. |
Back to top |
Eric John Guest
Posted: Wed Jun 06, 2007 7:55 pm Post subject: Re: 830 cracked heads |
The 930 case has a smaller bore. I do not believe that the heads will work. |
Back to top |
