SC adjustable wide front rebuild
SDLars
PostPosted: Tue May 22, 2007 4:34 am    Post subject: SC adjustable wide front rebuild Reply to specific post Reply with quote
I'm working my way on from back to front on my SC and am now trying to figure how to rebuild/take the wear out of the rear pivot point on my adj wide front. What kind of experiences have you folks had?
Glenn F.
PostPosted: Tue May 22, 2007 8:25 am    Post subject: Re: SC adjustable wide front rebuild Reply to specific post Reply with quote
I completely rebuilt the adjustable wide front ends on my SC and DC. I had all 4 king pins spray welded and machined to factory specs. I did the same with the main pivot shafts. I then installed all new bushings. I paid $400 for each of the front ends to begin with.
Going AWF proved to be a rather expensive notion.
Glenn F.
SDLars
PostPosted: Tue May 22, 2007 11:49 am    Post subject: Re: SC adjustable wide front rebuild Reply to specific post Reply with quote
How about that ball and socket arrangement on the rear pivot of the SC? I have a couple of ideas but was wondering what others have done.
C. Amick
PostPosted: Thu May 24, 2007 8:35 am    Post subject: Re: SC adjustable wide front rebuild Reply to specific post Reply with quote
The socket piece on mine was broken. I made a new socket out of a piece of 1-inch thick steel that I had. I cut the steel and drilled the bolt holes and the machine shop cut the depression for the ball. I also added a grease plug.
