Need David Brown Crankshaft
Tom N MS
PostPosted: Tue May 22, 2007 6:36 pm    Post subject: Need David Brown Crankshaft Reply to specific post Reply with quote
Need crank(want new one) for a DB 4/47A..Need front and rear seals, main bearings, rod bearings, pan gasket..Numbers cast in the broken crank are D908453 and stamped above this cast # is G6704. Can someone refer me to a source where I can ge this on order. I am needing to get it back together. Thanks
Elmer
PostPosted: Wed May 23, 2007 3:31 am    Post subject: Re: Need David Brown Crankshaft Reply to specific post Reply with quote
I have one ground .010 under size. Can help with bearings and gaskets. I strongly doubt you will find a new one. ejlandman@sympatico.ca
