H60E transmission problems
Elanier81
PostPosted: Tue Apr 02, 2019 11:55 am    Post subject: H60E transmission problems Reply to specific post Reply with quote
Was wondering if anyone had any idea where I could get a O-ring kit # 142897H3 for a H60E PAYLOADER with S-700 International transmission
Elanier81
PostPosted: Tue Apr 02, 2019 12:03 pm    Post subject: Re: H60E transmission problems Reply to specific post Reply with quote
These are new pressure numbers for all gear positions. All pressures were taken at the same time by having different gauges on all clutch packs and torque converter at same time.
Elanier81
PostPosted: Tue Apr 02, 2019 12:04 pm    Post subject: Re: H60E transmission problems Reply to specific post Reply with quote
Sorry about posting picture of the pressures twice
AJ.
PostPosted: Sat Apr 06, 2019 4:25 am    Post subject: Re: H60E transmission problems Reply to specific post Reply with quote
Can't help with the o'rings cept suggest matching them up at the hydraulic shop or obtain a box of assorted ones,the figures you posted do not mean anything to me,for the moment concentrate on first gear forward,find the port for the gauge for first gear,attach the gauge start the engine select first and note the pressure,fix the gauge to forward,start the engine and note the pressure,at this point the machine should have drive,if the pressure is zero and the pump is good there is a leak internally,the regulator valve could be leaking,the clutch cut-out dumping the oil or something else that is common to both clutch packs,I do not have a schematic of the oil path to be able to make a suggestion,its unlikely both the first and forward clutch would fail at the same time,esp when parked?.
AJ
Elanier81
PostPosted: Fri Apr 12, 2019 4:10 am    Post subject: Re: H60E transmission problems Reply to specific post Reply with quote
AJ,
across the top, forward, reverse, 1st,
2nd, 3rd, oil supply and torque converter.
Down the left side neutral, forward and
reverse for each gear. We had a seperate
gauge on all clutch packs, the oil supply
and the torque converter simultaneously.
We did this to confirm that we had stopped
all the leaks in the selection valve.
Before we replaced all the O-rings in the
selection valve we had oil bypassing and
going to multiple clutch packs at the same
time. Now, it appears that our leakage is
internal.
I did have a heavy equipment mechanic tell
me that I could be reading that good
pressure on third gear at the clutch pack
where the gauge is attached but still be
losing it internally behind that.
We are now looking at pulling the first
gear clutch pack which is outside of the
transmission and replacing the O-rings on
the end of the shaft where the oil supply
goes in to the shaft. And then we can also
see if the inner and outer seals on the
Piston itself are bad. If just the O-rings
on the end of the shaft are bad, we are
hoping that we can pull the cover plates
at the other clutch packs and replace the
O-rings on the end of the shaft where the
oil Supply goes into the shaft.
The mechanic also told me that changing
the fluid, which we have done, in an older
machine, can cause the old seals / O-rings
to not seal properly anymore.
Am I getting correct information from the
mechanic?
Also the top chart is at idle. The second
chart is at higher RPM which is what the
manuals tell you to do to check real
pressures. As you can see by the pressures
in 3rd gear it appears that it should be
running unless it is bypassing past the
pressure gauge, as the mechanic told me
could be happening?
