Allis Chalmers B is not idling
Dkalsow
PostPosted: Thu Apr 04, 2019 10:26 am    Post subject: Allis Chalmers B is not idling Reply to specific post Reply with quote
Good afternoon,
My Allis Chalmers B is not idling. It has to be just under 1/2 throttle for it to idle.
Does anyone have any steps I can use to trouble shoot the issue?
Dick L
PostPosted: Thu Apr 04, 2019 1:34 pm    Post subject: Re: Allis Chalmers B is not idling Reply to specific post Reply with quote
You don't have enough detailed information. When you get below 1/2 throttle does it still stay at idle when the lever is clear back or does or die? When you push the throttle lever all the way forward does it actually run at the proper high speed? What all has been done to the tractor since it run properly?
From the little you gave it could be the cross over arm under the water outlet in the front out of adjustment.
Aaron SEIA
PostPosted: Fri Apr 05, 2019 2:43 am    Post subject: Re: Allis Chalmers B is not idling Reply to specific post Reply with quote
New issue? Change anything recently? On my boys, the gov lever works its way out of the housing and makes the throttle go goofy. Like Dick said, we need more info.
AaronSEIA
Dkalsow
PostPosted: Fri Apr 05, 2019 4:33 am    Post subject: Re: Allis Chalmers B is not idling Reply to specific post Reply with quote
Thanks for everyone's help. I will answer the questions the best I can. The tractor was my fathers and I purchased it after he passed. From what I remember, my father could have that idle down to the first notch. Now it needs to be about half throttle to idle. Unfortunately, before he died he no longer had the ability to think as he once did. When I got the tractor it not run and my father could not figure out why. So I don't know what he might all have tired. When I got it, I did a compression test on it and each cylinder is consistent at about 50 PSI. I was able to get the tractor running by replacing the Magneto. The one on it was not giving spark and was for a International. He still had the original Allis Mag and it was hot. I had to change the wires to match the mag, but that got it running.
I hope this helps.
Aaron SEIA
PostPosted: Fri Apr 05, 2019 6:39 am    Post subject: Re: Allis Chalmers B is not idling Reply to specific post Reply with quote
https://drive.google.com/file/d/1nvxDDuq8gSc9ex2Y4n4wH3OWvMt8Foeb/view. Here is an on line PDF of the service manual. All the adjustments and settings for the throttle should be in there.
AaronSEIA
