Author |
Message |
Dwashebek Regular
Posted: Sat Apr 06, 2019 7:08 am Post subject: antifreeze leak |
I have a very slight antifreeze leak in my 1953 SuperH. When I say slight, it?s maybe 2-3 drops in two weeks time. I already checked the hose clamps. Any suggestions for an additive I can pour into the radiator without damaging anything? |
Back to top |
rustred Tractor Guru
Posted: Sat Apr 06, 2019 7:10 am Post subject: Re: antifreeze leak |
where is it leaking from? check water pump packing and tighten. |
Back to top |
Dwashebek Regular
Posted: Sat Apr 06, 2019 7:27 am Post subject: Re: antifreeze leak |
I don?t think it?s the water pump but I?ll take a closer look. How would I tighten the packing?
Than you! |
Back to top |
Posted: Sat Apr 06, 2019 7:59 am Post subject: Re: antifreeze leak |
there is a brass nut with tabs in from on the shaft. there is also a special wrench used for this. most people use a punch and hammer to tighten the nut. has to be pretty snug. plus give it couple shots of grease. if nut is bottomed out the packing needs to be replaced. just went through all this on my w9. |
Back to top |
fastfarmall Tractor Guru
Posted: Sat Apr 06, 2019 8:13 am Post subject: Re: antifreeze leak |
There is a product called K seal, it's suppose to be for slow leak's,i used it on my car, it stopped that from going down!! |
Back to top |
rustyfarmall Tractor Guru
Posted: Sat Apr 06, 2019 1:08 pm Post subject: Re: antifreeze leak |
Silver Seal. 2 cans should be enough. It is a powder. I use it in all my tractors just as a precautionary thing. |
Back to top |
Mark Poss Long Time User
Posted: Sat Apr 06, 2019 2:38 pm Post subject: Re: antifreeze leak |
Course black pepper |
Back to top |
Russ from MN Tractor Guru
Posted: Sat Apr 06, 2019 5:12 pm Post subject: Re: antifreeze leak |
Silver seal worked for me, and old tube my dad had. I normally use Bar's stop leak. |
Back to top |
caterpillar guy Tractor Guru
Posted: Sat Apr 06, 2019 5:14 pm Post subject: Re: antifreeze leak |
For a couple drops in a couple of weeks I would not fuss with it. |
Back to top |
