Post hole depth
BarnabyHooge
PostPosted: Mon Apr 08, 2019 5:36 pm    Post subject: Post hole depth Reply to specific post Reply with quote
Used my Woods Equipment post hole auger for the first time today and it bottomed out at 36" or so. I figured there must be an extension for it, but I'm really not seeing them anywhere. Would have thought everyone would have them. Do folks just use the standard length bit and leave the depth as is?
hd6gtom
PostPosted: Mon Apr 08, 2019 8:04 pm    Post subject: Re: Post hole depth Reply to specific post Reply with quote
If your setting a corner post no. You gotta take a pair of
jobbers and a spade and make the hole deeper. A 7' line post
that is ok.
BarnabyHooge
PostPosted: Tue Apr 09, 2019 4:32 am    Post subject: Re: Post hole depth Reply to specific post Reply with quote
That makes a lot more sense. Thanks!
CVPost-hd6gtom wrote:
(quoted from post at 21:04:48 04/08/19) If your setting a corner post no. You gotta take a pair of
that is ok.
BarnabyHooge
PostPosted: Tue Apr 09, 2019 4:57 am    Post subject: Re: Post hole depth Reply to specific post Reply with quote
that is ok.
redforlife
PostPosted: Wed Apr 10, 2019 8:23 pm    Post subject: Re: Post hole depth Reply to specific post Reply with quote
No, a 36" hole is not deep enough. Measure how high your 3 point raises the auger off the ground. Minus about 3 or
4 inches off of that measurement. Take auger off digger, and take to a welding shop, and have them make a bolt on
extension for the measurement you came up with.
As for depth of holes, I always try to plant atleast 4' of post in the ground. I dig holes deeper if I can. Saves
from having to clean out the loose dirt that always falls back in. I don't mess with any posts shorter than 9'. If
I do things right, I end up with 5' of post out of the ground.
Texasmark1
PostPosted: Thu Apr 25, 2019 4:16 am    Post subject: Re: Post hole depth Reply to specific post Reply with quote
I use a 36" because I post hole dig with a Ford 3000 with Live PTO (perfect for PH digging) and that's all it can take. On fall backs into the hole, when I am at the max depth I push in the clutch, thus stopping the rotation of the PTO, lift it straight out of the hole and when the bottom of the auger clears the hole, I let the clutch out. 95% of the "finds" sling off, out of the way.
Destroked 450
PostPosted: Thu Apr 25, 2019 7:53 am    Post subject: Re: Post hole depth Reply to specific post Reply with quote
Depends on location and soil type but augers range from 3 ft to 6ft long, mine are 4 ft.
I like a 3-3 1/2 ft hole for using a 8 ft post so that I have 4 1/2 - 5 ft of post sticking out.
Ground here packs good so a deep hole isn't needed, also if we go very deep we hit rock.
For loose sandy soil or deep frost lines you may need to go deeper.
Google: auger bit extensions.
I found several from 12" to 3 ft.
Post new topic    Yesterday's Tractors Forum Index -> Using Your Tractor & Crop Talk All times are GMT - 8 Hours
