1969 M670 restore
Scout2008
PostPosted: Sun Apr 14, 2019 10:33 am    Post subject: 1969 M670 restore Reply to specific post Reply with quote
I am almost done with the 670 restore. Just a few little details to finish. It's been over a year to get here since I started the restore. This tractor had sat out for an extended period at some point in it's life. It had a lot of rusty pieces, and I had to replace most of the bolts due to the rust and pitting. I had to do extensive work on the seat, and got a new shock from ChrisQ that works great. I had the hydro pump rebuilt, had to put a new clutch in it, had the card rebuilt, and had to clean up the wire harness. It ran good, and had good compression so I did not go into the engine. Unfortunately after I painted it it developed a leak at the torque seal, and I had to split it again, which surprisingly did not mess up too much paint. Here are some pics of the process. I started with hot water pressure wash with aircraft paint remover, then used the wire wheel. One in the paint booth used epoxy primer, primer sealer, then Martin Senor paint. Grill came from Stamm's, decals R-M, and alot of parts from Wendell Everett.
gtractorfan
PostPosted: Sun Apr 14, 2019 11:51 am    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Wow! This is something I dream about. We had a 670, wish we'd kept it.
larry Mi
PostPosted: Sun Apr 14, 2019 12:57 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Great Job. The old 670 really looks great.
molinegb
PostPosted: Sun Apr 14, 2019 2:45 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Nice job on 670. Question on 66 U302 super. Was it yellow? Have one same but is yellow with brown under. Early 66?
Scout2008
PostPosted: Sun Apr 14, 2019 4:38 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
This one was a brown belly when I got it. No yellow that I could see.
centash
PostPosted: Sun Apr 14, 2019 5:13 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Wow! Beautiful work!
Ben
Whiskey Bent
PostPosted: Sun Apr 14, 2019 5:45 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
You do great work and should be very proud of yourself!
Alan K
PostPosted: Sun Apr 14, 2019 9:20 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
That is simply awesome. You do excellent work.
Fufu602
PostPosted: Mon Apr 15, 2019 5:34 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Looks fantastic. Did you get the hydraulic system vibration problem figured out that you had asked about on here awhile back?
View user's profile MSN Messenger
shinnery
PostPosted: Mon Apr 15, 2019 6:52 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Beautiful, I have a '65-LP you can start on when you are ready.
Scout2008
PostPosted: Tue Apr 16, 2019 11:58 am    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
I turned down the presssure adjustment screw on the pump which solved to issue.
Scout2008
PostPosted: Tue Apr 16, 2019 4:14 pm    Post subject: Re: 1969 M670 restore Reply to specific post Reply with quote
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
