Governor Linkage Briggs Stratton
Rod in MN
PostPosted: Sun Apr 14, 2019 12:42 pm    Post subject: Governor Linkage Briggs Stratton Reply to specific post Reply with quote
HI I have a Briggs & Stratton Model 190412 Type 2738 01 Code 83051912 Having problems Governor and Throttle linkage and Gov. spring. I can not find a Manual on this model to down load free?
Anyone have a picture of the linkage. It is on a snow blower with a knob on top of the engine that you move up and down . it's idle or wide open to where it would go Bang Any help would be very helpful
Thank You
Rod in MN
View user's profile Yahoo Messenger
Bob
PostPosted: Sun Apr 14, 2019 2:32 pm    Post subject: Re: Governor Linkage Briggs Stratton Reply to specific post Reply with quote
If this happened suddenly, the governor itself may have self-destructed.
First, check that the the position of the governor arm on the governor shaft is correct, using the procedure quoted below. If it sill goes from idle to "wide open" with no governor action, likely it will be necessary to disassemble the engine for a look at the governor itself.
"Static Governor Adjustment
Horizontal Crankshaft
1. Loosen screw holding governor lever to governor
crank.
2. Rotate throttle plate linkage from idle position to
wide open position. Note direction of rotation of the
governor arm attached to the throttle linkage.
3. Place and hold the linkage in high speed position.
4. While holding the linkage in this position, use an
appropriate tool to rotate the governor shaft until it
stops in the direction noted in step 2.
5. Tighten screw holding governor lever to governor
crank. Torque to 35 ? 45 in. lbs. (3 ? 5 Nm).
6. Before starting engine, manually actuate governor
linkage to check for binding."
Email me if you want more detailed info.
bigcoulee@hotmail.com
Duner Wi
PostPosted: Wed Apr 17, 2019 4:17 am    Post subject: Re: Governor Linkage Briggs Stratton Reply to specific post Reply with quote
This should get you free pdf manuals
https://www.briggsandstratton.com/na/en_us/support/manuals/results.multiStepManualSearch.html?searchrequested=190412-2738
