Hard Starting Issue
Cedar-Ridge
PostPosted: Thu Apr 18, 2019 12:15 pm    Post subject: Hard Starting Issue Reply to specific post Reply with quote
I picked up a 49 8N early last winter. The snow fell and I didn't get a chance to mess with it untill now. I started with the basics, tune
up, clean the fuel system, rebuilt the carb and an oil change. Its hard to start but once it does start the throttle only seems to work from
about midway and up. I read a bunch of posts and tested a bunch of items and it's still the same. I did notice that when I put the throttle
lever all the way down the governor rattles. Increase the throttle and the rattle goes away.
Could the hard starting issue be caused by the governor?
Bruce (VA)
PostPosted: Thu Apr 18, 2019 12:49 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
" Could the hard starting issue be caused by the governor? "
No. The absence of low speed throttle response is caused by the governor. See tip # 14.
The hard starting can be causes by a number of things.
6v or 12v?
Is your battery fully charged?
75 Tips
Cedar-Ridge
PostPosted: Thu Apr 18, 2019 2:12 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
12 volt
Battery is fully charged
Thanks for the ?tips?. Very helpful!
Bruce (VA)
PostPosted: Thu Apr 18, 2019 2:29 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
Are you using a 12v coil?
75 Tips
Cedar-Ridge
PostPosted: Thu Apr 18, 2019 2:35 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
That I don?t know. How can I tell if it?s 6v or 12v?
Bruce (VA)
PostPosted: Thu Apr 18, 2019 2:46 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
Put an ohm meter on it. 2.5 ohms or so, it's 12v. And it only needs the oem ballast resistor if it's a 12v coil. If you have the additional ceramic resistor, you could easily have too much resistance in the circuit.
Run a jumper wire from the battery directly to the coil and try to start the tractor. Just don't leave it hooked up if the tractor is off. See tip # 30.
What did you set the points at?
Did you set the timing?
75 Tips
Hobo,NC
PostPosted: Thu Apr 18, 2019 5:39 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
You been MIA you must have been hammer down plant'N...
Bruce (VA)
PostPosted: Thu Apr 18, 2019 5:45 pm    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
I'm almost a week early. All tomatoes in
last week. Okra today, corn tomorrow. You
got everything in yet?
Hobo,NC
PostPosted: Fri Apr 19, 2019 3:30 am    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
Its to wet to plant so wet I my yard is a swap...
Bruce (VA)
PostPosted: Fri Apr 19, 2019 4:38 am    Post subject: Re: Hard Starting Issue Reply to specific post Reply with quote
Yep, the "real" farmers around here are
having serious problems getting in the
fields. Normally, field corn would have
been planted 2 weeks ago and tomatoes
would be going in as we speak.
