full face respirator and wearing eye glasses
Goto page 1, 2  Next
td466
PostPosted: Mon Apr 29, 2019 11:36 am    Post subject: full face respirator and wearing eye glasses Reply to specific post Reply with quote
hello
can you wear glasses with a full face respirator? If not is there a certain spectacle kit someone recommends ? I have a opti-fit full face respirator if that helps?
Stephen Newell
PostPosted: Mon Apr 29, 2019 12:07 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
There shouldn't be a problem wearing glasses under the mask except they have a tendency to steam up. They make some anti-fog cloths to clean your glasses or you can clean them with soft soap and wipe them dry instead of rinsing them. The trace of soap helps prevent them from fogging.
td466
PostPosted: Mon Apr 29, 2019 12:16 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
ok but where the arms go back to my ears it breaks the seal on the mask. I'm getting fumes coming in at that point, not a lot but enough to bother. I have a low pressure air fed respirator that puts out 5 cfm to my mask, I'm not sure why it still comes in because of the positive pressure in the mask?
any help would be greatly appreciated
yakob
PostPosted: Mon Apr 29, 2019 12:54 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
CVPost-td466 wrote:
(quoted from post at 14:36:15 04/29/19) hello
You evidently don't have enough cfm. Did your mask come with a little tester to check for this?
td466
PostPosted: Mon Apr 29, 2019 12:55 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
yes, how much cfm do I need then?
Duane WI
PostPosted: Mon Apr 29, 2019 6:00 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
I wear reading glasses for close up work like painting. I cut the bows off a pair and tied on strings. Elastic would also work. If you have an old pair of prescription glasses this would work. This works well for me using a full face supplied air respirator.
Stephen Newell
PostPosted: Mon Apr 29, 2019 6:33 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
Yes you reduce the quality of the seal with the glasses however like others have said if you have sufficient volume of air the air should be going out there instead of in. The problem is with the pump rather than how the mask fits your face.
td466
PostPosted: Tue Apr 30, 2019 5:58 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
I've got a 3/4 hp pump with 10 cfm max, and have 50' of intake hose for clean breathable air at all times with 100' of out let. I'm wondering if the outlet hose is too long? also on a day that it 60 degrees F, the air to the mask gets really hot. is that from the long outlet hose?
thanks
yakob
PostPosted: Tue Apr 30, 2019 6:20 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
CVPost-td466 wrote:
(quoted from post at 08:58:39 04/30/19) I've got a 3/4 hp pump with 10 cfm max, and have 50' of intake hose for clean breathable air at all times with 100' of out let. I'm wondering if the outlet hose is too long? also on a day that it 60 degrees F, the air to the mask gets really hot. is that from the long outlet hose?
thanks
My guess is that the inlet hose is the problem. I use 100' of outlet on mine with no hot air even on 90 F days.
I think you are overworking the pump and the inlet is not letting you get air through. Why do you have an inlet in the first place? I just set my pump outside.
Dune Country
PostPosted: Tue Apr 30, 2019 10:43 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
where is the pump?, you might just be recirculating your fumes
View user's profile AIM Address
yakob
PostPosted: Tue Apr 30, 2019 10:50 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
Dune Country wrote:
(quoted from post at 13:43:54 04/30/19) where is the pump?, you might just be recirculating your fumes
I think it is in its original packaging on a shelf for the time being.
td466
PostPosted: Tue Apr 30, 2019 10:51 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
the intake is at the opposite end of building outside, its coming in thru my mask you can see it on the face seal
td466
PostPosted: Tue Apr 30, 2019 10:56 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
yakob, is your 100' hose full through? I got 2 50' hose sections hooked together with a quick coupler between them, someone told me one time that 2 50' sections together will cause restriction?
yakob
PostPosted: Tue Apr 30, 2019 11:16 am    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
CVPost-td466 wrote:
(quoted from post at 13:56:07 04/30/19) yakob, is your 100' hose full through? I got 2 50' hose sections hooked together with a quick coupler between them, someone told me one time that 2 50' sections together will cause restriction?
I honestly can't recall, but I do think mine is one piece. It is corrugated hose as well which would be more restrictive than something smooth theoretically. Is yours corrugated?
Rather...what system do you have? I have the "BreatheCool" one from Turbine Products.
The quick coupler on mine seems to have a pretty good hole in it but you might swap that out for some garden hose connections like on the ends or some other kind of splice and see if it helps. I would not think that the coupler would explain the temperature of the air being high, though.
Try some things while you aren't painting: Get rid of the intake hose and see if the temp corrects itself.
Dune Country
PostPosted: Tue Apr 30, 2019 12:02 pm    Post subject: Re: full face respirator and wearing eye glasses Reply to specific post Reply with quote
Pardon my ignorance here, but, why do you need a exhaust hose, mine does not have one just a one way valve.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
